Interesting Failure Today
/ Interesting Failure Today #21
Reminds of a time when I was young and worked in a yard that piggy backed semi tractors to transport across the country. I drove one up to the staging area and it wouldn't shut off. I seen a button that said "emergency shut off" so I hit it and sure enough the engine stopped. Boy did I catch h#ll for that. The older guy I worked with told me to never do that again and if the engine doesn't stop just put it in the highest gear and drop the clutch. I won't forget that bit of advise soon.
Hmm. Did you ever find out why you weren't to use the emergency shut off? :confused:
I dunno, that new belt doesn't look it is going to work ... :laughing:
New design, held together with a metal buckle, makes installation a breeze.
On my tractor with a key solenoid shut off I notices a lever safety wired shut on the side of my injector pump. Curious guy I am, I cut that wire free and actuated the lever with engine running. Instant shut off!
I have since looked at mine and it has a lever also.
/ Interesting Failure Today #24
So I attached a nice thin flexible line to that lever and routed it to the cab with a small red knob attached.
Home brew emergency shut off!
I'm thinking it might be a good idea to find the emergency shut off on my tractor too... Thanks for the suggestion. :thumbsup:
/ Interesting Failure Today #25
In the oil patch guys have to run a positive air shut off on there diesels as they can intake H2S gas and run on that and have a run away.
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2012 HINO 268A 4X2  26FT NON CDL BOX TRUCK (A59906)
2012 HINO 268A 4X2...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2012 John Deere 6170R (A57148)
2012 John Deere...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
