Interesting Failure Today
/ Interesting Failure Today #21
Reminds of a time when I was young and worked in a yard that piggy backed semi tractors to transport across the country. I drove one up to the staging area and it wouldn't shut off. I seen a button that said "emergency shut off" so I hit it and sure enough the engine stopped. Boy did I catch h#ll for that. The older guy I worked with told me to never do that again and if the engine doesn't stop just put it in the highest gear and drop the clutch. I won't forget that bit of advise soon.
Hmm. Did you ever find out why you weren't to use the emergency shut off? :confused:
I dunno, that new belt doesn't look it is going to work ... :laughing:
New design, held together with a metal buckle, makes installation a breeze.
On my tractor with a key solenoid shut off I notices a lever safety wired shut on the side of my injector pump. Curious guy I am, I cut that wire free and actuated the lever with engine running. Instant shut off!
I have since looked at mine and it has a lever also.
/ Interesting Failure Today #24
So I attached a nice thin flexible line to that lever and routed it to the cab with a small red knob attached.
Home brew emergency shut off!
I'm thinking it might be a good idea to find the emergency shut off on my tractor too... Thanks for the suggestion. :thumbsup:
/ Interesting Failure Today #25
In the oil patch guys have to run a positive air shut off on there diesels as they can intake H2S gas and run on that and have a run away.
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2014 DODGE 5500 SERVICE TRUCK (A67714)
2014 DODGE 5500...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2017 Crane Carrier Co. T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
