Intellipanel mph/kph
   / Intellipanel mph/kph #1
buck12
Mississippi
Kubota 5460HSTC
My new Grand L 5460 shows speed in kph and fuel usage in liters. This is not covered in the manual. I did several TBN searches and found instructions on some older threads. In a couple of these threads it mentions that the factory setting is for R1 tires (I have R4s) and there is code that should be entered. One of the threads gives a code for the 4060 however the 5460 has different sized tires. Does anyone know the code for the larger Grand L (4760, 5460, 6060)?
   / Intellipanel mph/kph #2
Operation coefficient (tire size code) for L5460 and L6060 with R4 tires is 2012.
This is in the Assembly Instructions on page 30.
SDT
Thank you very much. I didn’t get any manuals with the tractor other than FEL and RC. The dealer sent me a PDF of the operators manual until the hard copies arrive.
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
