Intellipanel mph/kph
/ Intellipanel mph/kph #1
buck12
Mississippi
Kubota 5460HSTC
My new Grand L 5460 shows speed in kph and fuel usage in liters. This is not covered in the manual. I did several TBN searches and found instructions on some older threads. In a couple of these threads it mentions that the factory setting is for R1 tires (I have R4s) and there is code that should be entered. One of the threads gives a code for the 4060 however the 5460 has different sized tires. Does anyone know the code for the larger Grand L (4760, 5460, 6060)?
/ Intellipanel mph/kph #2
Operation coefficient (tire size code) for L5460 and L6060 with R4 tires is 2012.
This is in the Assembly Instructions on page 30.
SDT
Thank you very much. I didn’t get any manuals with the tractor other than FEL and RC. The dealer sent me a PDF of the operators manual until the hard copies arrive.
2026 Steel Pines Cargo 7x14 Enclosed Trailer, VIN:7FWBE1424T1036524 (A61166)
2026 Steel Pines...
2016 Bobcat E20 Mini Exacavtor (A61567)
2016 Bobcat E20...
2004 Ford F-250 4x4 Pickup Truck (A61568)
2004 Ford F-250...
2022 Case CX220E Hydraulic Excavator (A61567)
2022 Case CX220E...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2014 Ram 1500 4x4...
