Instant Pond
/ Instant Pond #201
OK, I am new to tractors and am major league jealous of the equipment you folks have. I am buying my first tractor now. Just a grey market 2210 Yanmar 4x4 to play with on 175 acres in Idaho. I know nothing about tractor except that I need one and what I am buying is all I could currently afford.
I recently moved from Northern Nevada to my property in Idaho that I purchased over 9 years ago. Six or seven years ago I paid just over four grand for some local pond developers to build me a pond and do some heavy dirt work cutting the top off of a potential hill/ home site. My buddy from Nevada who does dirt work said he would have charged 10 times that for the 7 days work in all.
In any case this is part of what they did. This is my little pond. It approx 2 acres in size when it full in the spring. Its fed by run off but is also on a spring which helps keep it fed. Its approx 12 feet deep in the spring and maybe 7 or so when its a drought year like this year.
I have many many more spring on my property which need to be developed. I have one that I is developed and just runs of into the hillside and is wasted. I will remedy that soon. My plan is to put two higher ponds in my little canyon that will help feed this lower pond so water is not wasted as it runs off all spring like a small river.
However no little Yanmar will handle this and I will hire the pond guys again. Since we just moved I managed to get my shop up and am adding to it next spring. Hope to get a home built someday in front of the pond. All power, septic well, internet ect is in and works. Just need cash to build a home.
There are a few catfish in this pond now and more to come plus bass and blue gill. There are a couple thousand frogs and they are loud.
By the way, so its not confusing. The pond pics with the shop and trailer are the newest pics taken recently and thus the pond is at its lowest as you can see the outline for most of the year. It really drops off in late Sept. The pics with no buildings are the pond when new. The tall trees are actually a island designed for birds that works until September when the level drops and allow predators to access it. When I get the springs directed to it, this should help keep the level up some. Those trees are a good 40 feet high in spots and the island is full of thistle of birds. It always has ducks and geese on it. We get some cool visitors too! One pic shows the **** which is probably 20 feet high at the end and 120 yards around or so.
In any case I love this thread and wish I could afford the nice stuff but will have fun building my garden, greenhouse, chicken coupe and pheasant pens this spring and summer with the help of the little Yanmar.
RUMBLON
/ Instant Pond #202
Wow...talk about tractor envy. I'm sure most of the guys here would give there left lugnut to have a setup like youre starting with. Beautiful place you have there!
Sent from my Motorola Moto X using TractorByNet
/ Instant Pond
RUMBLON
Rumblon,
I am envious of your "spread". I is very nice. Especially the views. Is that trees on the dam or on the back side of the dam in the photo. You know their roots will grow to the water and could cause enough leakage to drain you water? Do you mind if I ask how much the 175 acres set you back?
hugs, Brandi
/ Instant Pond #205
Rumblon,
hugs, Brandi
According to the folks I know here and the guy who did my pond and guy who did my septic the only thing I have to worry about is that there is a muskrat population. Its almost solid mud once you get into the soil. The HUGE belly dump cutter or what ever it was called was slicing up 12 ft pieces of clay before they broke down. There is zero added to the dirt in this pond. Its all natural and the muskrat population has been dwindled down a LOT. I would like to hear more opinions on the dam end trees however.
This piece has three buildable permits on it for three homes and can be divided. My plan is to get my two daughters on it down the road. One will be a breeze and loves it. The other will be the choir. That said this piece is 9/10ths of a mile long. Its probably in the 300K range as it sits. Thats not what I bought it for 9 years ago.
RUMBLON
/ Instant Pond #206
Rumblon,
hugs, Brandi
Brandi, I will do more research as EVERYWHERE I look on the internet it say to not allow trees on the **** end. The ones there now are small and can easily be cut down at this point. I doubt the current root system will be an issue but they will eventually be a LOT bigger.
thanks for the heads up. I will look intoo it more.
RUMBLON
/ Instant Pond
RUMBLON
RUMBLON,
It's not just the trees, but the roots. If they have made it to water.........and rot away.........instant siphon holes.
hugs, Brandi
/ Instant Pond #208
RUMBLON,
hugs, Brandi
I understand but if I need to do it and cut them, now is the time as the water is lower and the trees are visiable at the ground level. Plus they are small one to two inch trunks. If I wait it will be a bigger issue as there is no huge root system yet that I can see like ones I just researched or the roots in the bigger trees on the other side of the pond.
RUMBLON
/ Instant Pond
RUMBLON
Better now than later. Still..............you have a beautiful place.
hugs, Brandi
/ Instant Pond #210
Thanks Brandi, it will be when its done. At 52 its not as easy as it once was. BVuying this little Yanmar will help out a lot hopefully. This spring the shop gets another 500 sq ft on the right side and a mid room in front of that shed side with the windows which I am now building my rock hearth in. It will be semi livable if need be. Right across from the shop the barn goes in and down where the trailer is, one day a barn style home to match the shop. The shop will be covered in cedar. I used what I had. I am adding a passive solar greenhouse this spring and our garden. We are having a blast. Lots to do. Thanks for the heads up.
RUMBLON
/ Instant Pond #211
52 PFFfffftttttttt Wait until you hit 60 or 65, or 70, or 75...................
:eek:
/ Instant Pond #212
nice looking spread for sure, I would also suggest no trees around the pond d-a-m for reasons already given. That D-A-M could be raised up some and widened up a bit if ya wanted the top looks a bit narrow near the top & backside from the distant pic...
Mark
/ Instant Pond
I got the last of the posts put in last Wednesday, in the cold and wet. Wet, as we still have run off meandering behind the dam. I put all the treated 2x12s up today. I think I might at another sloping wing on the far end. I know for sure when I get the dirt on the dam all leveled back out.11-30-13 Island Pond Bulkhead Construction.jpg11-30-13 Bulkhead Shaping Up.jpg
It seems I have an Indian tractor, a diesel generator from Italy, a skil saw from Japan, and a pancake compressor from China. My American made dog didn't make the photo, as he was laying in the sunshine.11-30-13 Mutli National Tool Collection.jpg
It took a lot of trimming with my chain saw to get the cedar posts all squared up for the 2x12s. Stihl saw, I'm not sure if it is made here or in Germany. I would "assume" there is a factory here.
hugs, Brandi
/ Instant Pond #215
I got the last of the posts put in last Wednesday, in the cold and wet. Wet, as we still have run off meandering behind the dam. I put all the treated 2x12s up today. I think I might at another sloping wing on the far end. I know for sure when I get the dirt on the dam all leveled back out.View attachment 348188View attachment 348189
It seems I have an Indian tractor, a diesel generator from Italy, a skil saw from Japan, and a pancake compressor from China. My American made dog didn't make the photo, as he was laying in the sunshine.View attachment 348187
It took a lot of trimming with my chain saw to get the cedar posts all squared up for the 2x12s. Stihl saw, I'm not sure if it is made here or in Germany [Unquote]
The Stihl is made in Virginia Beach. I used to live 1/2 mile from the factory. At the time,('70's) it was the only Hot Die cast plant in the States. I still have mine from 1980. (Wood Boss 028).
/ Instant Pond
Tom,
I have the Stihl Farm or Ranch Boss. I have had it for about 10 years with no problems. Dad always got the Poulans. Which I refer to as a throw away saw.
hugs, Brandi
/ Instant Pond #217
The dam is really looking good.......and I agree about the Poulans.....the only thing their good for is making me mad.
Charlie
/ Instant Pond
Charlie
Thanks Charlie. As wet as it is and is going to get, it will be a while before grass is growing around the bulkhead.
hugs, Brandi
/ Instant Pond
Happy Day. I came home this morning and while driving around the curve of the driveway, I saw a flash out of the corner of my eye at the pond. I turned to see it was a Mallard Drake taking off. He landed about 25 feet away from where he started. I dashed in the house for the camera. But could not see him from my back deck. So I faked Booger out towards the barn and tried to get in closer. He saw me and flew up into the heavy trees across the fence.
I'm definitely Happy, happy, happy.
Now, what can I plant to attract more wild ducks?
hugs, Brandi
X (A68191)
X (A68191)
2006 FORD E450 UTILITY TRUCK (A66091)
2006 FORD E450...
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A65056)
2017 GENIE GTH-844...
2000 Hino (A64194)
2000 Hino (A64194)
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
11 R24.5 Tires - Set of 2 (A68134)
11 R24.5 Tires -...
