Installing Remotes connections
/ Installing Remotes connections #1
mhelvestine
Ford 1715
Hello to all I just purchased an offset Flair mower and have installed the 2 spool valve but I can't seem to find where I hook the valve to so I can get the hydraulics to the mower at on my 1715 Ford tractor. Any point in the right direction would be great help I don't have any loader on this tractor either. I did notice a diverter block near the pump and it has plugs on the side of the block, wondering if I can pull off that? Mike
/ Installing Remotes connections #2
That block with the plugs is what you're looking for. Your two spool valve needs to be power beyond configured to operate properly. That's your starting point. If it's not PB capable, you should seriously consider exchanging it for one that is.
You need to remove those three plugs, install fittings and three hoses to/from the new valve, then rotate the spool in the block. It only turns about 1/2 turn or less.
2015 Polaris Ranger 570 (A62183)
2015 Polaris...
2017 Ford Fusion Hybrid Sedan (A61569)
2017 Ford Fusion...
New Holland 3930 (A60462)
New Holland 3930...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2016 Ford F-250 Crew Cab Pickup Truck (A61568)
2016 Ford F-250...
3ft. Wooden Cowboy Statue (A61569)
3ft. Wooden Cowboy...
