Installing PTO Jinma pump
/ Installing PTO Jinma pump #1
leslie428
Québec, Canada
Jinma 284 LE IH 434 with loader
Does anyone know if I need to empty fluids before I remove the back plate to install the Jinma PTO hydraulic pump? Thanks for your help.
/ Installing PTO Jinma pump #2
Hi..No you do not have to drain anything.You may get about a teaspoon of oil that seeped around the seal but that's all.
I made a extra gasket for installing the pump.and note that the mounting bolts with the pump are slightly longer than the ones in the cover plate. /forums/images/graemlins/smile.gif
Thanks for your answer, will be placing the order with Tommy of Affordable today. If I understand correctly I will need a new gasket everytime I take the pump off and put it back on when using and not using the backhoe. Right?
/ Installing PTO Jinma pump #4
I won't claim to have much Jinma knowledge but, I did just look at the exact set up you are working with. I didn't see the gasket it came with but, the cover was off. I didn't look like it would be too hard to make an extra gasket out of a rubber gasket material from an auto parts store. Lube the gasket with a little oil prior to installation and it should come off easily on disassembly, without damage, ready for re-use. I'm sure Tommy @ Afforable will have a knowledgable suggestion.
/ Installing PTO Jinma pump #5
Yep you can reuse the gasket..It's not really for sealing any oil in or out..Just a slight cushion for the metal to metal contact.I think the orig. on the cover plate was made of cork.I made one with some old gasket material I had laying around.
Thanks for your input. I am now waiting for the delivery of the pump. Tommy of Affordable tractor was good enough to send me the UPS tracking number so I will be able to follow the delivery. Thanks again to you and all those that cared.
Adams Nurse Trailer Tank (A63118)
Adams Nurse...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
Trava Long Gooseneck Livestock Trailer (A64047)
Trava Long...
Case SV280B (A62177)
John Deere XUV825E (A61307)
John Deere XUV825E...
CAT 953 Crawler Loader (A61166)
CAT 953 Crawler...
