Boondox
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 3,884
- Location
- Craftsbury Common, Vermont
- Tractor
- Deere 4044R cab, Kubota KX-121-3S
Like most properties in this area, I have a pond. It's about 80 feet in diameter and about 8 feet deep. The berm is packed earth/clay, and the pond was built about 50 years ago so it's very stable.
But the overflow is thru a 12 inch culvert placed so close to the ground's surface that every winter it gets pushed up by the freeze/thaw cycle till it doesn't handle any overflow at all. And with all the snow melting, then the spring rains, that's exactly the time of year I need the thing the most! For a couple of generations now we've solved the problem by using 2" PVC lines to siphon off a couple inches after every rain. I'd like a more permanent solution.
Since a 2" line is adequate, I was thinking 4" heavy walled PVC would be fine. The berm nearest the stream (where the overflow dumps) is 24 feet thick. What I was thinking of using is essentially a 30 foot long section of PVC with the entire length angled downhill and the end sticking up at a 45 degree angle, sort of like a long hockey stick. With all the leaves we have each autumn any strainer would quickly be blocked, but with the pond end angled like that my thought was the water would start flowing the moment the level rose to the lip of the pipe...and if the water rose further it would reach the wider portion of the pipe and more would be able to flow. I hope I described that okay.
But I can't just dig all the way thru the berm in one shot, or the pond will drain out the ditch. Lowering the level isn't an option right now because my infeed was washed out and has to be fixed or I lose a lot of critters. What I was thinking was I'd dig half the trench, install the pond half of the PVC pipe with the end capped, bury it--then dig the other half, join the PVC sections, bury it all, and uncap the end. Would that work?
Is there a better way?
TIA, Pete
TIA, Pete
