Installing a 2 spool SCV on a JD 2320
   / Installing a 2 spool SCV on a JD 2320 #11
Here are several pictures of my 2 spool SCV that I recently installed on my JD 2320.
Wow - that's a nice installation. Very clean.
JayC
   / Installing a 2 spool SCV on a JD 2320 #12
Great job LT, that turned out great! Thanks for posting pictures.:thumbsup:
Thanks Kenny for all your valuable input and picutres to help me fix my problem and achieve a great install.
   / Installing a 2 spool SCV on a JD 2320 #15
My pleasure to help anytime.
The only change I would have made to to use 1/4" hose to extend the work ports-it's cheaper, takes up less real estate, and it's easier to route. Your 2320 does not put out enough GPM to need 3/8" hose. I have saved this in my favorites to show to others in the future looking to do the same.
Again, nice job.
   / Installing a 2 spool SCV on a JD 2320 #16
Great looking install, where did you get that tool box? wonder if one could be made to fit a 2305?
I purchased the toolbox on line but can't remember the web site......sorry. I do know that I found it by doing a google search for tractor toolbox. Tractor Supply sells one on-line in 4 different colors as well. The measurements of their tractor toolbox is the same as the one I purchased.
   / Installing a 2 spool SCV on a JD 2320 #18
Thanks, I will give it a shot...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
MACK GR64F DUMP TRUCK (A59823)
MACK GR64F DUMP...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
24in pin on excavator tooth bucket (A56436)
24in pin on...
