Installing a 2 spool SCV on a JD 2320
   / Installing a 2 spool SCV on a JD 2320 #11
Here are several pictures of my 2 spool SCV that I recently installed on my JD 2320.
Wow - that's a nice installation. Very clean.
JayC
   / Installing a 2 spool SCV on a JD 2320 #12
Great job LT, that turned out great! Thanks for posting pictures.:thumbsup:
Thanks Kenny for all your valuable input and picutres to help me fix my problem and achieve a great install.
   / Installing a 2 spool SCV on a JD 2320 #15
My pleasure to help anytime.
The only change I would have made to to use 1/4" hose to extend the work ports-it's cheaper, takes up less real estate, and it's easier to route. Your 2320 does not put out enough GPM to need 3/8" hose. I have saved this in my favorites to show to others in the future looking to do the same.
Again, nice job.
   / Installing a 2 spool SCV on a JD 2320 #16
Great looking install, where did you get that tool box? wonder if one could be made to fit a 2305?
I purchased the toolbox on line but can't remember the web site......sorry. I do know that I found it by doing a google search for tractor toolbox. Tractor Supply sells one on-line in 4 different colors as well. The measurements of their tractor toolbox is the same as the one I purchased.
   / Installing a 2 spool SCV on a JD 2320 #18
Thanks, I will give it a shot...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Ford F-350 (A55973)
2019 Ford F-350...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
