inspection pit
/ inspection pit #1
enterprisebbc
Ct
2008 CK35 Kioti
Has anyone built a pit in a garage, or car port floor? There is a British fibreglass pre made one to lower in the ground, or I could build one. I have even thought of using a ceptic tank and lower it into the ground with a ladder and rail for a seat on the inside. Or large ramps with or alone with the aformentioned. Any ideas?
/ inspection pit #2
Before lifts were available, pits used to be really common.
Lots of people fell into them when a car wasn't over the pit.
Bruce
/ inspection pit #3
We have one at work. We built it out of formed concrete with concrete steps. If I had to do it again I would get a pool contractor to do it.
I think it would be less dollars. We put a 4x4 angle iron along the edge.
We have a rolling oil pan for oil changes. The pit is great for inspections and oil
Changes, but limited in other areas ie a transmission jack won't work.
We have painted the edges safety yellow and have a chain with removable post.
Falling in is a big risk. More likely a visitor than those around it daily.
Some have butterfly doors and some have rolling hatches.
It takes up a whole bay and unless you do a lot of oil changes, probably not ideal.
The money spent on a pit could almost equal a full lift and less lost floor space.
South of the border they use exterior drive up ramps that are about 4 feet tall and each ramp is about 2 feet wide with a space in between.(there probably some in the US, but not as visible) easier to built off a hill side.
/ inspection pit #4
The pit MUST HAVE a fresh air source, along with lighting and emergency access.
The smarter the idea is in thought, sometimes the dumber pursue it without caution!
JW5875
/ inspection pit #5
We have one at work also, concrete steps, safety ropes, rolling drain pan and mega lighting. Very neat setup.
No fresh air.
/ inspection pit #6
We used to run the car over a ditch, pull the hand brake and go to work. Sucked in rainy weather tho. Good for minor repair only. Today's cars are super low... won't even clear standard ramp. Getting harder to do your own work.
/ inspection pit #7
If it were me, I'd get a lift before a pit any day. Do you have the height clearance for a lift?
4Shorts in Newfoundland used to have a pit in one of his garages, and he filled it in last year.
/ inspection pit #8
I used to rent a house with a pit in the garage.
It was frequently flooded with several inches of water, and unless it is very long, it is possible to drive a car over it blocking all ways to get out. You do not want one like this.
/ inspection pit #9
You are absolutely right my friend. I filled it in after having it for 20 years. It was in one of my shops that wasn't used anymore for maintainnance but to tell the truth it was just a death trap and very dangerous.
Pits are nothing more than a hole in the floor and you have to realize that gasses collect in them and can cause a fire and or an explosion while your working in them. Don't ask me how I know this :(
The fact is that pits have become so dangerous that Occupational Health & Safety here put a ban on them and if you have one you must fill it in.
25 years ago I worked in an area where the company had pits throughout there full area. They were used to service 150 ton haulage trucks and even back then they were ordered to fill them in.
I can only imagine what an insurance companies policy would be on them as well. Just something to ponder. :eek:
/ inspection pit #10
I also worked in a building that had a pit. It was only about 66" deep with steps on one end, and it was always dry. It was nice for tractors, but other vehicles were usually a pain. Unlike many; however it was built with an extra lip about an 1-1/2" deep. This allowed us to use 2x10's as a cover when it wasn't being used. It actually was covered about 99% of the time and didn't get used very much.
/ inspection pit
Well I could have the height as I havent built the carport or what ever yet but before I do and pour the floor I was thinking of this pit thing. I'm thinking that the cement place near here could has ceptic tanks and maybe its an idea if they are not to much. Just a thought. A lift would be thousands. I agree on you political correctness theory. Has runied a lot of things.
/ inspection pit #12
A friend of mine just had a storm shelter put in his garage. This is basically a pit with a sliding lid. You can utilize it as service pit with the cover slid open. My friend was bragging about this ability, however he seldom does any of his own maintenance anymore. Be sure to have a way to clean out the spills. I used one as a youngster and cleaning up spilled oil was a real pain!
/ inspection pit #13
Seems to me a lift would have a lot more flexibility, a pit would kind of pigeon hole you into certain types of work.
/ inspection pit #14
I think you'll find a lift to be far cheaper than excavating the ground, getting a septic tank or forming a pit, pouring it, etc, etc, etc.
Check out Bend-Pak and Northern Tool for models and pricing.
Thanks regarding my political correctness comment.
/ inspection pit #15
I can't think of a common precast septic tank size that would be anywhere narrow or long enough to be useful as the basis for a service pit.
Count me among those who think a pit is a supreme waste of square footage and dollars.
/ inspection pit #16
Pit / pigeon hole
Pun intended
Seems I've heard they will not insure a place that has them .
Probabl would cancel a police if a pit was found on e piece of property .
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2015 ISUZU NQR TRUCK (A59904)
2015 ISUZU NQR...
2017 Thompson 32HPU 55kW Towable Pump (A59228)
2017 Thompson...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
