Input Welcome
/ Input Welcome #1
wa4jk
Ford 49 8N
First Post here and would like some input.
First I have had nothing but a 9N and then an 8N for farm use since I was a kid and that has been 50 years ago. Now I need a new modern tractor for our Goat operation. So I have narrowed it down to some specs.
1. 35-40hp
2. 30-35PTOHP
3. FEL
Needs to be able to lift round bales.
Due to my previouse tractor experience I reall would rather have a 8X2 gear shift, that is because I don't know enough about shuttleshift and such.
I do not think I need 4wd either. What I need is a good old heavey framed reliable tractor without a lot of maintenance junk to break or bells and tricks.
I have narrowed it down a bit ( in no particular order)
1. LSg3038 $16800 w/fel
2. MF 2605 $17000 w/fel ( $11900 w/o fel) ?? Why is the FEL so high on MF's 66" bucket
3. Mah 4035 $ ??????? Can't get a quote, they say come on in and we'll talk.
So what say the crew about the list..
I will be shreading, draging and stacking hay. Cleaning out barns and lots. Just general farm utility use.
Thanks
/ Input Welcome #2
Have you considered Kubota MX 4700 or 5100? They are a little higher hp than your range but are good tractors. They will handle round bales with ballast in the tires and on the 3 point hitch.
/ Input Welcome
Lift Cap =
1. Kubota MX 4700 :2310lb
2. LSR3039:1808lb ( had the wrong info in above)
3. MF 2605: 3195lb
4. mah 4035: ?? not on spec sheet
/ Input Welcome #4
Check out the JD 5000 series. Basic tractor with plenty of capabilities. Bought mine New in 2008 and tractor w/o FEL was around 14k. FEL was another 5k. Decent used machines for around 15k with FEgood luck.
/ Input Welcome
How about the Price on the MF 2605 w/fel the over the phone quote is $17000. Breakdown is $11900 for the Tractor only. Does that seem reasonible??
/ Input Welcome #6
Lift Cap =
3. MF 2605: 3195lb
Those numbers look a bit off (low) to me, but they're too high to be 800mm specs.
LS shows the max lift for the R3039 at 2,250@ the pivot pin.
Kubota shows max lift for the MX 4700 as 2,443 @ the pivot pin.
MF shows max lift for the 2605 as 2,650, 2,859, and 2,952 @ the pivot pin for the L200, L210, and DL250 loaders .
/ Input Welcome
Pulled those right off the published paperwork. Might be wrong, might be right.
I talked to the Mah dealer and he has a 4025 2wd with Koyker fel $15200.00 4025 2wd with Mahindra fel $16500.00
Don't know much about the FEL's.
Anyone have any comments on these. Wife says I have to buy this weekend.. She's so pushy
Kubota Z232 (A60462)
2011 FORD F-150 (A63569)
2011 FORD F-150...
SET OF (9) CENTRIFUGAL PUMPS (A63569)
SET OF (9)...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
New Holland TC21 (A62177)
New Holland TC21...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
