Injured B2320
/ Injured B2320 #1
Engine Mike
Rochester hills michigan
Kubota B2320
I was moving a very big pile of stumps from clearing land to build my new pole barn. I poked a stick into the grille which is basically a plastic holder with a metal screen. The screen is bent up but looks like it can be reshaped. Because the screen is bent up the plastic holder and screen assembly does not fit very well. Has anyone had this experience and have any tricks or advice to fix this?
/ Injured B2320 #2
I put a stick through the grill of a JD 955 that I owned. I just carefully bent the grill back to where it should be and sealed the hole that was left with a bit of clear silicone.
/ Injured B2320 #3
I put a stick thru my B26 grill. I pushed it back in place with the help of some C clamps, then mixed up some JB WELD and glued it back together from the back side. The repair is barely noticeable from the front side.
