Injector pump timing
/ Injector pump timing #1
Leonard malone
Kioti ck 25
I'm looking for any input on setting injector pump timing on a 2006 Kioti ck 25 . its getting harder to start and runs rough for the first couple minutes after starting. Also a lot of black smoke. Any suggestions would be appreciated. Thanks, Len
/ Injector pump timing #2
Do you have reason the think the timing is off? Has the pump been off? Unless you have reason to believe the timing has changed from the factory setting I’d look elsewhere for a problem.
/ Injector pump timing #4
Wish I could help. I know there are marks to line up but I’ve never done it myself.
(3) Pieces of 30' Sticks of Heavy Wall Poly Pipe (A62679)
(3) Pieces of 30'...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
