Injector pump timing
/ Injector pump timing #1
Leonard malone
Kioti ck 25
I'm looking for any input on setting injector pump timing on a 2006 Kioti ck 25 . its getting harder to start and runs rough for the first couple minutes after starting. Also a lot of black smoke. Any suggestions would be appreciated. Thanks, Len
/ Injector pump timing #2
Do you have reason the think the timing is off? Has the pump been off? Unless you have reason to believe the timing has changed from the factory setting I’d look elsewhere for a problem.
/ Injector pump timing #4
Wish I could help. I know there are marks to line up but I’ve never done it myself.
2023 Kubota L2501HST (A64126)
2023 Kubota...
Metal Sunflower Statue (A64127)
Metal Sunflower...
Bulk Bin (A66408)
Bulk Bin (A66408)
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
