Injector pump question
/ Injector pump question #1
Ben Hucks
John Deere 4050. 6130d
Installed a new injector pump about a month back or so. You guys helped a lot on that. Got another question. My tractor is a 1985 4050 with a 466 non turbo motor. It has a stanadyne rotary pump. What could I expect to gain if I turned it up. I have been told that I can turn it up 10%. What effects will it have on the motor if I turn it up. Just wondering. Any input would be great
/ Injector pump question #2
Does the motor smoke any now under heavy load? If you are reasonable with the adjustment you will gain some hp. If there is no or very light haze under load then I would turn it till you get some smoke. After that you will need to be careful as you can get some high exhaust temps.
Another option is to add a turbo charger. Just buy the kit for 4250 tractor.
/ Injector pump question #3
You have a 27 year old tractor. I take it, that it works OK adding extra fuel, can severely damage a lot of things, besides just the engine.
I would leave it stock, and have a long happy life, get the nozzles tested, that will give you efficiency.
/ Injector pump question #4
The 4050 is about 100 hp so a 10% increase will not hurt the engine or the tractor. They regularly come from the factory 10% over.
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
UNVERFERTH H25 - 25' HEAD CART (A64277)
UNVERFERTH H25 -...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
Landhonor 65' Extension Cord Reel (A66408)
Landhonor 65'...
Aproximately 72' of Steel Catwalk (A62679)
Aproximately 72'...
