Fuel injection pumps with there own oil bath, what oil are you using in it ?
Mar 9, 2020 / injection pumps #1 L Leejohn Elite Member Joined Sep 16, 2007 Messages 4,039 Location Doniphan, Mo. Tractor Kubota L4240, B7800 & BX2660 Fuel injection pumps with there own oil bath, what oil are you using in it ?
Mar 9, 2020 / injection pumps #2 F finn1 Platinum Member Joined May 10, 2009 Messages 899 Location Upper Michigan, Marana Az. Tractor Kioti CK4010 hst, Cab, Deere 26G excavator, K1500 w/ Boss 7’6” plow, F450 dump W/ Boss 10’ straight blade Super Duty plow, F250 reg cab, F350 cc drw, Case TR310 CTL Same engine oil specifications as the engine. Haven’t seen an engine that has a pump with its own lube system, not connected to the engine supply in years, though.
Mar 10, 2020 / injection pumps Thread Starter #3 OP L Leejohn Elite Member Joined Sep 16, 2007 Messages 4,039 Location Doniphan, Mo. Tractor Kubota L4240, B7800 & BX2660 This is for a friend, it's for his 5000 ford and his dozer. They both are that way. I also told him I would guess engine oil but that I would ask here TYN to see what others said.
Mar 11, 2020 / injection pumps #4 T thepumpguysc Elite Member Joined Apr 14, 2010 Messages 3,349 Location South Carolina Tractor Injection Pump Rebuilder yup, whatever u put in your engine.. The drain is on the bottom, the FULL is on the side & the FILL is the big nut on top..
Mar 13, 2020 / injection pumps Thread Starter #5 OP L Leejohn Elite Member Joined Sep 16, 2007 Messages 4,039 Location Doniphan, Mo. Tractor Kubota L4240, B7800 & BX2660 Thanks you guys this does help.
