injection pump timing
/ injection pump timing #1
cody323
Mountain Home Idaho
Yanmar 187D
i need some help. i removed my injection pump on my 187. i installed it the way it is described in the service manual but i can not get it to prime and time. the book tells you to pull the decompression arm and rotate the engine by hand until fuel comes out of the number one injection port. i tried this but spun the engine for about five minutes and no fuel ever came out. i made sure that the rack pin of the pump was in the yoke and that i had fuel flowing to the pump. any ideas??
/ injection pump timing #2
If this is a keyway type of engagement to the pump drive gear, any chance that key didn't make it back correctly ?
the pump is operated by a cam shaft as far as i can tell. i dont know where any gears come into play. it is the same pump, is it possible to install it and prime it as you normaly would? i did not change anything so does timing still come into it?
/ injection pump timing #5
The timing is set by the number of shims under the pump. As long as you put the same shims back in the timing will not change. Even if it was WAY out of time it would still pump fuel-just not exactly at the right time. Why did you remove the pump? Was there a problem with it before you took it out?
Aaron
Parts@HoyeTractor.com
(940)592-0181
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
John Deere 2155 (A62177)
John Deere 2155...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
1998 STOLL 35' GOOSENECK LIVESTOCK TRAILER (A63291)
1998 STOLL 35'...
