Information on battery "issue"
/ Information on battery "issue" #41
Re: Information on battery "issue"
bz1 said:
I have not had problems with my new 2520 but only 28 hours on it. Has anyone tried just putting the battery in a plastic battery case and mount the whole thing in the tractor. I think that eventually all batteries other than sealed maintenance free and gel units will eventually leak. Looks like there's enough room in my 2520 for a plastic battery box if there is one the correct size.
Plastic battery box is a good way to handle the leaking acid if there is enough space and you can find correct size. However, I doubt if there is enough space in the 4x20 battery compartment to accomodate both battery and box. I'll probably end up going with the Optima solution.
/ Information on battery "issue" #42
I have a 4310 that has since replacing the factory battery has now gone threw 3 batteries. There seems to be a low current drain even with the key off all switches off of about 12ma so that in three to four days the battery is dead dead and will not take a charge. Napa has been yeomen about replacing it but I do not think they will cont. Ideas?
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
2017 Caterpillar 308E2 (A64126)
2017 Caterpillar...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
2018 Ram 1500 Crew Cab Pickup Truck (A61573)
2018 Ram 1500 Crew...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
CATERPILLAR CS44B...
