Info on FF225
/ Info on FF225
Ernie,
Now that Spring has sprung, I'm more willing to get outside and work on stuff (not that we ever got a good winter out here). I cleaned off the injector pump and cranked the old girl up. It seems that the fuel is leaking from the right-hand connection. If you notice in the pictures I posted earlier, the "clamp" (for lack of a better term) that holds the right two outlets together is a couple of mms higher than the left one. I don't know what the function of those clamps are other than to keep the bottom connections from turning.
I assume that the top connections are standard compression fittings. Should I loosen the top fitting, tighten the bottom one, and then re-tighten the top one?" If that doesn't fix the problem, I guess I'm looking at replacing the injector line and maybe the fitting that goes into the pump.
Thanks,
Dodd
/ Info on FF225 #12
The lines use copper washers on the banjo fittings, if they are missing, it will leak.....:D
2018 John Deere 5075E (A60462)
2018 John Deere...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2016 FORD F-250 (INOPERABLE) (A60736)
2016 FORD F-250...
