Info needed on Iseki TS2510 hydralics
   / Info needed on Iseki TS2510 hydralics #1
Daddyd
Riverview, FL
Iseki TS2510
Lifting speed is way too fast, a slight movement of the up lever sends the implement jerking up too fast. I have changed hydrualic fluid and cleaned suction line screen, made no difference. Also, is there an adjustment for the lifting speed control? Thanks, Daddyd
Thanks Marcel I'll look for the T handle.
   / Info needed on Iseki TS2510 hydralics #4
The T handle usually changes the down speed, but not the lift speed, but thats a good suggestion. I know that on some Iseki's there is also a knob below your behind your knees when you sit down, and that will control the lift speed. It's tough when it is all in Japanese. You may just have to play with some of the knobs.
   / Info needed on Iseki TS2510 hydralics #5
Usually the problem is too slow a lift. You can put a restricter valve in the line. Email me if you can't find one.
Thanks Mitch & Leonard for your replys,I'll let you know what happens when i find time to work on my tractor, maybe this week;
Tim
2025 JMR 40in Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
