Info needed on Iseki TS2510 hydralics
   / Info needed on Iseki TS2510 hydralics #1
Daddyd
Riverview, FL
Iseki TS2510
Lifting speed is way too fast, a slight movement of the up lever sends the implement jerking up too fast. I have changed hydrualic fluid and cleaned suction line screen, made no difference. Also, is there an adjustment for the lifting speed control? Thanks, Daddyd
Thanks Marcel I'll look for the T handle.
   / Info needed on Iseki TS2510 hydralics #4
The T handle usually changes the down speed, but not the lift speed, but thats a good suggestion. I know that on some Iseki's there is also a knob below your behind your knees when you sit down, and that will control the lift speed. It's tough when it is all in Japanese. You may just have to play with some of the knobs.
   / Info needed on Iseki TS2510 hydralics #5
Usually the problem is too slow a lift. You can put a restricter valve in the line. Email me if you can't find one.
Thanks Mitch & Leonard for your replys,I'll let you know what happens when i find time to work on my tractor, maybe this week;
Tim
LOT OF CHICKEN EQ. NEST, BROADER & FEEDER (A58374)
LOT OF CHICKEN EQ...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
5' ROTARY MOWER (A52708)
5' ROTARY MOWER...
22' x 23' All Metal Garage (New/Unused) (A59225)
22' x 23' All...
(2) 225/75D15 TIRES W/ 5 LUG RIMS (A52708)
(2) 225/75D15...
