Info for adding front remotes
/ Info for adding front remotes #1
duramax1
NORTH CAROLINA
I am wanting to add a set of remotes on the front of the fel on my TC 45 in order to add a grapple attachment. Can anyone give advise as where to start and what additional valves ect. will be needed?
/ Info for adding front remotes #2
Dmax1, I built a tree snipper and had to run one remote to the front of the FEL to run the jaws. It's on a 1910 Ford which is a Shibaura platform as is yours. Basically I added a spool in series; the following picture shows hose A to the FEL spools, hose B out of the FEL spool to the new spool and hose C out of the new spool to the manifold block.
New spool plumbed in series
Here is the thread.
Tree snipper with hydraulics added to front
The later Attachment/pictures in the thread detail the hydraulic details, including the first picture above. It was straight forward- I spent the most time on securely mounting the new spool /forums/images/graemlins/crazy.gif
/ Info for adding front remotes #3
I had duel rear remotes, so I chose to run (permanant) hoses from the rear to the front and mount another quick connect block.
So far it has worked well for me. The few times I need a rear remote, I just unplug a hose at the rear during that operation.
I did try mouning an electric selector valve first, but had problems with leak down ETC, so I abandoned that route.
/ Info for adding front remotes #4
My Kubota Grand L3130HST has three factory remote valves. In order to support a tree shear with rotation capability the "plumbing" is setup this way. Circuits 1 & 2 have QDs at the back. Circuit 2 is teed so that Circuits 2 & 3 run forward. QDs are installed on the loader mount to allow the loader to be removed. Circuits 2 & 3 are then extended to QD blocks mounted on the loader cross member for hydraulic connections there. I have a quick attach option so I can interchange the tree shear and a bucket with a grapple. It all works great.
Vernon
/ Info for adding front remotes #5
Vernon, what are "QD's" /forums/images/graemlins/confused.gif
/ Info for adding front remotes #7
wrlonginc has a valve kit for FEL including a handle to put on your loader joy stick with a thumb button to open and close your attachment.
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2023 Wallenstein BXTR6438 Towable Woodchipper (A66734)
2023 Wallenstein...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
DIAMOND TOOLBOX (A68842)
DIAMOND TOOLBOX...
1998 TRAIL KING TK70HT HYDRAULIC TAIL TRAILER (A67714)
1998 TRAIL KING...
2016 Chevrolet Express Shuttle Bus (A66736)
2016 Chevrolet...
