Info for adding front remotes
/ Info for adding front remotes #1
duramax1
NORTH CAROLINA
I am wanting to add a set of remotes on the front of the fel on my TC 45 in order to add a grapple attachment. Can anyone give advise as where to start and what additional valves ect. will be needed?
/ Info for adding front remotes #2
Dmax1, I built a tree snipper and had to run one remote to the front of the FEL to run the jaws. It's on a 1910 Ford which is a Shibaura platform as is yours. Basically I added a spool in series; the following picture shows hose A to the FEL spools, hose B out of the FEL spool to the new spool and hose C out of the new spool to the manifold block.
New spool plumbed in series
Here is the thread.
Tree snipper with hydraulics added to front
The later Attachment/pictures in the thread detail the hydraulic details, including the first picture above. It was straight forward- I spent the most time on securely mounting the new spool /forums/images/graemlins/crazy.gif
/ Info for adding front remotes #3
I had duel rear remotes, so I chose to run (permanant) hoses from the rear to the front and mount another quick connect block.
So far it has worked well for me. The few times I need a rear remote, I just unplug a hose at the rear during that operation.
I did try mouning an electric selector valve first, but had problems with leak down ETC, so I abandoned that route.
/ Info for adding front remotes #4
My Kubota Grand L3130HST has three factory remote valves. In order to support a tree shear with rotation capability the "plumbing" is setup this way. Circuits 1 & 2 have QDs at the back. Circuit 2 is teed so that Circuits 2 & 3 run forward. QDs are installed on the loader mount to allow the loader to be removed. Circuits 2 & 3 are then extended to QD blocks mounted on the loader cross member for hydraulic connections there. I have a quick attach option so I can interchange the tree shear and a bucket with a grapple. It all works great.
Vernon
/ Info for adding front remotes #5
Vernon, what are "QD's" /forums/images/graemlins/confused.gif
/ Info for adding front remotes #7
wrlonginc has a valve kit for FEL including a handle to put on your loader joy stick with a thumb button to open and close your attachment.
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2017 Ford Transit 250 Cargo Van (A66736)
2017 Ford Transit...
