Info button
/ Info button #1
Dallas_Lilly
Flagstaff AZ
Montana 4340C
Just bought a brand new T474 cabbed tractor. Anyone figure out how to change the Celsius to Fahrenheit?
/ Info button #2
Here is the procedure I found from the TYM Tractors Owners Facebook group:
Here's a simple way on 474 I published Aug 23. Not sure if it works on 574 but what do you have to lose?
"Change dash temperature reading.
You can easily change the displayed engine temperature from Celius to Farenheit, or vice versa. This very simple procedure can be done while tractor is running, or just turn ignition on. My tractor is a 474 hydro for reference, new with just 40 hours.
Change temp from C to F or the opposite.
1-Turn ignition on, wait a few seconds.
2-Depress then release Info button so dash reveals voltage & temperature.
3-Turn headlights on bright.
4-Depress & continue holding Info button approximately 15 seconds or until temp changes from Celius to Farenheit or vice versa.
5-Done." "
Hopefully it helps.
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
7065CFL (A64553)
7065CFL (A64553)
