Independent PTO problem, JD 2240, 1978
   / Independent PTO problem, JD 2240, 1978 #21
Not sure about removing the top cover
Thanks for link to drum. I just meant suggestions for places to check for it. I appreciate the trouble you went to for actual part. I will need one for the earlier model. The photo shown is not a match.
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
