Increasing Wheel Span/Tread on DK45
/ Increasing Wheel Span/Tread on DK45 #1
derifarm
N Yarmouth, ME
I just bought a DK45HST that I'm quite happy with! I want to make one change to my machine that I want to check first with all of you. I currently have AG tires on it and I'd like to get the space between the tires (inside span) to a little more than 46 inches (120 cm.) The specs in the manual show that I can turn the wheels out and with the AG tires should get to a little less than 45".
So, the question is: do you think it would be a problem if I were to put in a 3/4" spacer between each hub and wheel rim? Would this cause undue stress on any part of the tractor? Also, if any of you have an idea for a spacer, I'd love to hear it.
The purpose of this is so that I can straddle the bed I'm creating with my 46" Imants Spader. I'm going to try to create permanent sod tracks and only spade/till that space between.
-Justin
/ Increasing Wheel Span/Tread on DK45 #2
I think if I were you I would want a double lip on the spacer.
The inside lip should run on the axlel hub and the outside lip should have the rim riding on it.
I think you may be putting to much stress on the lug nuts by just putting a flat spacer on it.
/ Increasing Wheel Span/Tread on DK45 #3
deri -
Would you mind posting about your spader some time?
I'm thinking of moving raised beds and have been pondering tillage. I also have wheel spacing problems which presently limit me to 30". Going wider will mess up crops that i grow flat in rows. Oh well, I may just have to buy a second tractor...
Sure thing. I'll try to get some pictures and explanation on why I chose the Imants spader as soon as it arrives.
2022 EZ-GO ELITE...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
3pt 14' 15 Shank Chisel Plow (A64127)
3pt 14' 15 Shank...
90in. Work Bench (A65640)
90in. Work Bench...
