Increase hydraulic extended length
/ Increase hydraulic extended length #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I had no idea where to post this so here it is. It's one of those things I've undoubtedly seen hundreds of times but never looked at until recently.
I've seen a lot of posts here about the need or desire to have a greater 'throw' on a hydraulic cylinder than is possible (like 12" retracted and 32" extended). Well, here's a way to accomplish that kind of feat.
It appears to be a real simple solution. It's just two hydraulic cylinders pointing in opposite directions plumbed to open together and close together.
Here is one last picture taken in traffic. For all I know this is old news to everyone but me. Nonetheless, I thought it was a neat idea. /forums/images/graemlins/smile.gif
/ Increase hydraulic extended length #4
interesting concept, raymond forklifts use single acting cylinders setup the same way, welded beside each other to get the lift range, but i havent seen double acting cylinders setup that way before, i will have to keep that in mind next time i am making somethin hydraulic, thanks gary
/ Increase hydraulic extended length #5
We use to have these twin axle tandem trucks for hauling silage and they had rams inside of rams. There was two sets on each bed. If you didn't raise them level one side would lock up and you really had a mess. I think that is why they now use single rams but still use one inside of the other for distance.
murph
/ Increase hydraulic extended length #6
Funny you should mention that. I just pointed out that same setup on a cement truck to a co-worker about 4-6 weeks ago. They were pouring a sidewalk outside our window. Seems like a great idea. I was impressed. Co-worker thought I was looney tunes for getting so excited over construction equipment. /forums/images/graemlins/tongue.gif
/ Increase hydraulic extended length #7
</font><font color="blue" class="small">( and they had rams inside of rams )</font>
what you are refering to is known as a telescoping cylinder, they are generaly only single acting, the setup garry is showing is neat cause it can be made double acting
/ Increase hydraulic extended length #8
</font><font color="blue" class="small">( what you are refering to is known as a telescoping cylinder, they are generaly only single acting, the setup garry is showing is neat cause it can be made double acting )</font>
I knew there was a name for them, I just couldn't spit it out. And yes they were only single acting. The other set up was double.
murph
<font color="blue"> "Co-worker thought I was looney tunes for getting so excited over construction equipment." </font> /forums/images/graemlins/tongue.gif
I took these pictures in traffic with my cell phone. Can you imagine what the mixer truck driver must've been thinking? /forums/images/graemlins/crazy.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif
2022 EZ-GO ELITE...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
UNUSED WOLVERINE TDB-11-72W-72" BUCKET (A64281)
UNUSED WOLVERINE...
Kubota GR2020G (A63688)
Kubota GR2020G...
Kobalt Table Saw (A64119)
Kobalt Table Saw...
7 Barrel Masport Vac Pump (A62679)
7 Barrel Masport...
