Inch/lbs vs Foot/lbs
   / Inch/lbs vs Foot/lbs #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
Did you know there is a BIG difference between inch and foot lbs of torque?????
I was reading up on changing my trucks transmission fluid and adjusting the bands and didnt catch that the transmission band specs were given in INCH/lbs NOT ft/lbs...
I wonder how bad I would have messed something up if I had tightened the transmission bands down to 72 FT/lbs instead of the 72 IN/lbs specified..
It just goes to show you paying attention to details really can make a difference.. LOL
Just thought I would share that tidbit of info..
Brian
   / Inch/lbs vs Foot/lbs #4
I actually tightened one of the bolts on the exhaust manifold of my 77 dodge p/u to foot pounds. Of course it stripped out. I used a helicoil on that one and got the rest of them right. No problem so far.
   / Inch/lbs vs Foot/lbs #5
Brian
Half the folks here would call that a manufacturing defect or design flaw.
   / Inch/lbs vs Foot/lbs #6
Lots of fasteners are rated in oz/in of torque.
Just for argument, do you realize it should be lb/in and lb/ft instead of in-lb or ft-lb? :rolleyes:
   / Inch/lbs vs Foot/lbs #7
When you are referring to the torque output of an engine it is generally lbs.ft. When you are applying force to a wrench it is ft.lbs. (or inch lbs.)
   / Inch/lbs vs Foot/lbs #10
Does it really make a difference?
Does anyone have a link to some technical document that proves one or the other is correct?
Mini Excavator Ripper (A53316)
Mini Excavator...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A55788)
2009 Pierce 105ft...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
1990 TRAIL MASTER TRANSPORT TRAILER (A55745)
1990 TRAIL MASTER...
