Inch/lbs vs Foot/lbs
   / Inch/lbs vs Foot/lbs #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
Did you know there is a BIG difference between inch and foot lbs of torque?????
I was reading up on changing my trucks transmission fluid and adjusting the bands and didnt catch that the transmission band specs were given in INCH/lbs NOT ft/lbs...
I wonder how bad I would have messed something up if I had tightened the transmission bands down to 72 FT/lbs instead of the 72 IN/lbs specified..
It just goes to show you paying attention to details really can make a difference.. LOL
Just thought I would share that tidbit of info..
Brian
   / Inch/lbs vs Foot/lbs #4
I actually tightened one of the bolts on the exhaust manifold of my 77 dodge p/u to foot pounds. Of course it stripped out. I used a helicoil on that one and got the rest of them right. No problem so far.
   / Inch/lbs vs Foot/lbs #5
Brian
Half the folks here would call that a manufacturing defect or design flaw.
   / Inch/lbs vs Foot/lbs #6
Lots of fasteners are rated in oz/in of torque.
Just for argument, do you realize it should be lb/in and lb/ft instead of in-lb or ft-lb? :rolleyes:
   / Inch/lbs vs Foot/lbs #7
When you are referring to the torque output of an engine it is generally lbs.ft. When you are applying force to a wrench it is ft.lbs. (or inch lbs.)
   / Inch/lbs vs Foot/lbs #10
Does it really make a difference?
Does anyone have a link to some technical document that proves one or the other is correct?
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2022 FREIGHTLINER CASCADIA SLEEPER (A54607)
2022 FREIGHTLINER...
NOBLE R80 ROUGH TERRAIN FORKLIFT (A52705)
NOBLE R80 ROUGH...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
