In theory which blower would be better
   / In theory which blower would be better #11
If you want a blower to throw snow a long distance laterally you need one with a rotating drum as shown in the photo. Eliminating the chute from the path of the snow eliminates a lot of friction. There have been small blowers with this feature in the 1970's such as a walk behind by Gravely. I dont know the current market. The rotating drum design is found on more commercial units because it adds to the cost but I think a creative person could modify a blower to build in this feature.
Dave M7040
I have a Ford 1720 SSS and have used both a 3 and 4 blade snow blower.
When I was looking to purchase a new snow blower I was in the same situation, how big & which one to buy.
I also calculated the velocity & area of the fan to help my decision.
While your math may be correct in this instance speed works against you.
You need sufficient speed to throw it 20 or 30 feet not atomize it & throw it into the next county.
I would bet on the Ford that operates at 540 because it has twice the torque available to ingest, accelerate and throw the snow out the discharge.
The 4 blade (my current snow blower) discharges the snow much smoother & appears to be more efficient but 24 of snow or snow that is plowed at the end of my driveway by the state would bring it down to its knee痴 for lack of HP during the first full cut. That problem was solved 2 years ago when I installed a turbo on my Ford which solved the HP problem.
The 3 blade impeller is less efficient than the 4 blade but the HP used to accelerate the snow to 51 mph will in my opinion overload the Kubota.
My bet is that the Kubota running at 1100 rpm will struggle
Tim
You could be right. But Th blower on the Kubota is made by Kubota specifickly for this mower.
Bill
I hope the Kubota does as well as I am hoping. The front mount will make my life a lot easier. here are some pics.100_0479.jpg100_0480.jpg100_0481.jpg100_0482.jpg
   / In theory which blower would be better #14
IMHO front mount blowers are safer and easier on the body. (No twisting around to see where you are going.)
They are also more expensive. :(
   / In theory which blower would be better #15
I have 2 snow blowers. I have not used either one yet. I have a 5'6" McKee with a 24" 3 blade impeller on my (29hp) Ford tractor that operates at 540 rpm's. If I did my math correctly this blower will have a discharge velosity of 38 mph. On my Kubota (21hp)I have a 52" with a 16" 4 blade impeller that operates at 1100 rpm's. The discharge velosity on this comes out to 51 mph. Acording to the math the kubota should be the best blower. Am I missing any thing here. It will be interesting to see which one does better. Maby one will do better in wet snow and the other better with powder. We will see if the math lies if it ever snows here.
Bill
Kubota hands down!
Wet snow (slush) will be a pain for any open auger blower...
The rear blower front blade would be good for this task
   / In theory which blower would be better #16
In my experience you are overlooking one fan parameter which is the width of the blades. If the fan cannot get rid of the snow delivered to it by the auger(s) the blower plugs up and you have to slow down or stop for the fan to catch up.
Dave M7040
I agree....I have seen pto blowers that only have a 2" deep impeller while others have a 6" or more impeller depth. If the impeller diameters are the same, the wider blades will blow much more snow. Try a simple test. How much air does it blow out the chute at operating rpm?
The Kubota puts out a lot more air. I might finally get a chance to try them out later this week :thumbsup:
Bill
   / In theory which blower would be better #18
Bill
What's your definition of "better"?
All other things being equal, in general, the higher the tip speed the farther the throw. Similarly, the bigger the immpeller diameter, the larger the through putfor the same rpm and on and on.
Your case has different impeller diameters, different impeller blade counts, different impeller speeds, different widths, etc.
So what do you mean by better?
2001 Dodge Ram 3500 4X4 Flatbed Truck, VIN # 1B7MF33651J565664 (A54865)
2001 Dodge Ram...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A55851)
Tiger Mowers 80in...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
New/Unused 200lbs Cast Iron Anvil (A54865)
New/Unused 200lbs...
