In need of serious Lawn Tractor recommendations based on specific needs?? Thanks
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #1
DEWFPO
"Up High in the Rockies"
2009 Bobcat Toolcat 5600 D
I've done some research but am frustrated so I'd like recommendations from those of you who may have similar requirements.
Requirements :
>- Mowing deck no larger than 48", preferably 42" or less.
>- No striping left after mowing (uncut line between blades)
>- twin cylinder and at least 20 HP, gas or diesel. I'd prefer 24+ HP (I live at 7,100' elevation so I loose about 25% with altitude).
>- Locking differential (I need traction on slippery slopes), 4wd would be nice but I don't think I need it with a locker.
>- Tight turning radius (I have many obstacles to mow around on steep hills)
>- Comfortable Seat (I have a bad back and need all the support I can get)
>- Hydrostatic transmission (no more gear shifting for me)
>- Needs to be able to pull a small trailer (Max. 500 lbs). up and down rough slopes.
For right now let's not worry about price. I'll add that factor in after I see which model(s) best meets my needs.
My frustration : To get 4 wheel steer in a JD your at a 300 level tractor and about 5.5K, adding a locking differential takes you to a 500 level tractor and another 2K!
All recommendations and comments are appreciated.
DEWFPO
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #2
A Simplicity Broadmoor may fit. They come in 22hp / 44" and a 25hp / 48" flavors. Both have Briggs V - twin, auto traction, a hydro trans and a mesh seat. Not sure if the seat would suit your needs.
I had a older Broadmoor and I don't think their cut quality can be beat for the money.
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #3
How steep are the hills? Those are pretty tough requirements.
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #4
Seriously?
Good fast or cheap, pick two.
You want a small commercial zero turn that will pull a trailer. That's not so hard really. Gravely will set you right up. Zero Turn Lawn Mowers | Commercial Mowers
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #5
Seriously?
Seems he said price didn't matter for now and I don't recall him mentioning fast either.
Seriously.
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #6
IMO, a zero turn isn't a good choice for this job especially pulling a trailer on a hill. A zero turn pulls a trailer good, but not on hills.
Around 15% grade would be the steepest. I need to be able to cut in all directions around trees, rocks and such so I can't just go up/down the slope.
DEWFPO
I appreciate the comments and recommendations. I'll check out Simplicity and Ventrac also.
DEWFPO
P.S. Speed is not an issue. (I'm retired).
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #10
It sounds like you had a nice one figured out already, the JD 500. I haven't ridden one in a few years but they sure are nice.
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
2018 Dodge Journey (A50324)
2018 Dodge Journey...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
