In need of serious Lawn Tractor recommendations based on specific needs?? Thanks
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #1
DEWFPO
"Up High in the Rockies"
2009 Bobcat Toolcat 5600 D
I've done some research but am frustrated so I'd like recommendations from those of you who may have similar requirements.
Requirements :
>- Mowing deck no larger than 48", preferably 42" or less.
>- No striping left after mowing (uncut line between blades)
>- twin cylinder and at least 20 HP, gas or diesel. I'd prefer 24+ HP (I live at 7,100' elevation so I loose about 25% with altitude).
>- Locking differential (I need traction on slippery slopes), 4wd would be nice but I don't think I need it with a locker.
>- Tight turning radius (I have many obstacles to mow around on steep hills)
>- Comfortable Seat (I have a bad back and need all the support I can get)
>- Hydrostatic transmission (no more gear shifting for me)
>- Needs to be able to pull a small trailer (Max. 500 lbs). up and down rough slopes.
For right now let's not worry about price. I'll add that factor in after I see which model(s) best meets my needs.
My frustration : To get 4 wheel steer in a JD your at a 300 level tractor and about 5.5K, adding a locking differential takes you to a 500 level tractor and another 2K!
All recommendations and comments are appreciated.
DEWFPO
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #2
A Simplicity Broadmoor may fit. They come in 22hp / 44" and a 25hp / 48" flavors. Both have Briggs V - twin, auto traction, a hydro trans and a mesh seat. Not sure if the seat would suit your needs.
I had a older Broadmoor and I don't think their cut quality can be beat for the money.
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #3
How steep are the hills? Those are pretty tough requirements.
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #4
Seriously?
Good fast or cheap, pick two.
You want a small commercial zero turn that will pull a trailer. That's not so hard really. Gravely will set you right up. Zero Turn Lawn Mowers | Commercial Mowers
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #5
Seriously?
Seems he said price didn't matter for now and I don't recall him mentioning fast either.
Seriously.
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #6
IMO, a zero turn isn't a good choice for this job especially pulling a trailer on a hill. A zero turn pulls a trailer good, but not on hills.
Around 15% grade would be the steepest. I need to be able to cut in all directions around trees, rocks and such so I can't just go up/down the slope.
DEWFPO
I appreciate the comments and recommendations. I'll check out Simplicity and Ventrac also.
DEWFPO
P.S. Speed is not an issue. (I'm retired).
   / In need of serious Lawn Tractor recommendations based on specific needs?? Thanks #10
It sounds like you had a nice one figured out already, the JD 500. I haven't ridden one in a few years but they sure are nice.
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
Toro Workman Utility Cart (A51694)
Toro Workman...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
