Improving a Pellet Stove
/ Improving a Pellet Stove #21
I'm going to say right up front, I don't have experience with any pellet stove.
I only want to add a word of caution. A co-worker of mine started experimenting adding corn to his pellet burner to gain cost efficient heat. He used some internet guidance to give some things a try. Ended up almost burning his house down and ruining a several thousand dollar heater.
Just be careful, while I've never met any one of you, I'd really hate to see a similar circumstance or worse posted here.:)
/ Improving a Pellet Stove #22
Curiously, what happened?
/ Improving a Pellet Stove #23
A neighbor of mine heats with corn. He has a pellet type burner in the kitchen and a large corn burning boiler system in the basement. He gets a gravity wagon full of corn for payment of helping the farmer during harvest time and he stores it in the barn. The basement hopper can be filled from the back yard through a pcv tube. I think a person should use whatever fuel is locally available and cheap.
/ Improving a Pellet Stove #24
Also....some of the older pellet/corn stoves have an issue with fumes once the door gasket gets old. Check online for warnings and recalls. Have a co2 detector too.
/ Improving a Pellet Stove #25
My recollection is that he did not use actual heating grade corn. It had excessive moisture. It clumped in the feed assembly and somehow the fire backed up into there and burned through the area not designed to have fire in it. That caught the building on fire. Fortunately, he was able to control the fire until the fire department arrived. Building was saved, although with some smoke damage. Fire department destroyed the heater in the progress though.
/ Improving a Pellet Stove #26
I could cut and split enough firewood for my house in 2 days. How long would it take to produce a 5-7 cord equivalent of corn? Plus I can store firewood indefinitely.
I don't know, a year's worth of stove heat? 2, maybe three minutes..
YouTube
At 200 bushels the acre, and 3 mph, corn is picked up quickly.
My neighbor burned corn for a couple years in his pellet stove. The smell made me hungry for pop corn ;-)
/ Improving a Pellet Stove #27
So long as field shelled corn is magnetically cleaned (so as not to have any metal in it and at 15% RM or below, it's fine. Pellets here are $214.00 per ton and I'm getting free field corn this year (below 15%) so it will be a nice warm year in this house. Both propane tanks are full (80) percent and I have a 500 buck credit as well. Life is good in SE Michigan.
/ Improving a Pellet Stove #28
You're talking about gathering and storing. Corn takes months to get to that point. The woods are already full of dead or dying trees to gather. So planting and growing corn before you can gather it vs. gathering and splitting wood that's already there. Plus, the machines necessary to plant and gather corn cost a wee bit more than a chainsaw and splitter.
/ Improving a Pellet Stove #29
Why corn is 4 bucks+ a bushel at the co-op. You have inputs (fertilizer), planting, harvest, transportation the the co-op and dry down cost corn has to be 15% or less RM to burn. You cannot just 'plant' some and roast it later on. A combine alone is Anywhere from 100 grand (used) to over 250 grand new. That is a heck of a lot of wood.
If I had a woodlot, I'd use wood myself. I don't. With propane at what it is, compared to corn, it's a no go anyway. Wood pellets on the other hand at 200-225 a ton are viable against propane but still only for supplemental heat in this house. I like having a backup heat source.
Other issue with corn is storage. I have 2 1000 bushel grain tanks but most people don't. I feed corn to my cattle anyway, corn, supplements and DDG.
/ Improving a Pellet Stove #30
You just asked how long, and prefaced the question with "cut and split". How long did it take to grow those trees ? How long did it take for them to die? And if you feel gathering "dead wood" is easy, you may be mistaken.
Does the forester's term "Widowmaker" mean anything to you?
Plus the video was meant to be humor. corn is big business, home heating fire wood is not. 'Cottage industry.
The load of logs I'm cutting on cost $800. Black birch (pretty fair heat content) It will be gone the end of next winter. Then I'll get another load. I can't bring it in for that much $.
/ Improving a Pellet Stove #31
Went and bought a couple pallets of Michigan Hardwood pellets yesterday t Tractor supply. $214.00 per pallet all in. Got 'em home and unloaded them in the barn with my forklift. Now to get my free corn in the grain tank and I'll be 'all set' for the winter.
Life is good.
/ Improving a Pellet Stove #32
There are 'pellet' only appliances and then there are 'biomass' appliances. A pellet stove is built for combusting wood pellets only. It doe not have the feed system, nor the exhaust system capable of handling the added heat of burning coen or a mixture of them. Biomass appliances do.
They are usually controlled by an integrate circuit tat regulates the draft for combustion, controls the feed rate, monitors the firebox temperature to prevent over firing and have a 'burn pot' specifically designed to burn pellets or corn or a combination of both and in reality, don't cost much more than a pellet only appliance.
The one I have (had it for 10 years), basically operates itself. You supply the fuel (corn or pellets or a combination of both) and it burns them but constantly monitors itself for issues. You clean out the burn pot every couple days and it rewards you with excellent thermal efficiency (around 87%) and a nice warm heat as well as a nice viewable fire (through the heat resistant glass door.
/ Improving a Pellet Stove #33
Propane prices vary considerably by region, here in New England it's a pricey way to heat and you're more or less locked in to one provider...most gas companies will not fill a tank they don't own.
As far as pellets go, maybe I'm missing something but they seem to be a solution in search of a problem. They're a commodity, and as such are subject to price increases, shortages, etc. At least with firewood you can almost always scrounge something (even if it's not very good quality) if you live in the country. I don't see what you gain buy using pellets vs some other form of heat.
I used to get a permit to get firewood from national forest land...the permit was cheap, somewhere in the neighborhood of $25, and no one really cared how much you took. It had to be dead & down. I'd just go to an area that had been recently logged and get the treetops, branches, etc. Lotta work huffing it out of the woods, but a few weekends worth of work I'd get enough for a couple years. As I've gotten older that's less and less appealing, as you noted it's a lot of work!
Corn may be big business, but before this thread I'd never heard of using it for heat. Is this something new? Is it just feed corn or something else?
Dunno what part of Vt. you're in, but firewood dealers abound here in northern N.H., though if by "cottage industry" you mean mom & pop + a couple employees, yeah...they're all fairly small businesses.
I wish I could find log length loads for $800. Going rate here is in the $1100 range, this is for a 9-10 cord load. Mostly maple, some beech, ash or yellow birch. Still a bargain compared to cut & split.
/ Improving a Pellet Stove #34
Convenience. Lots easier to load pellets for some people than logs.
/ Improving a Pellet Stove #35
/ Improving a Pellet Stove #36
Even easier and cheaper to burn natural gas.
If you have it. Living where we live in the boonies, NG don't exist so it's alternative fuels. We are lucky to have fairly reliable electricity. Why we have a 25KW diesel powered standby genset.
/ Improving a Pellet Stove #37
Dedicated corn burning appliances have been around at least 50 years. I think 'Snowflame' was the first followed by Amazing Blaze.
/ Improving a Pellet Stove #38
I used a pellet stove one winter in my house. The constant noise, auger jamming, my raised electric bill and the fact that a pellet stove rated for 2,000sqft could hardly keep my 1,300sqft house warm was enough. Went right back to wood. Silent, dosnt jam, no electricity and always works.
Pellet stoves have there place. Small rooms, city lots, elderly people or people who dont want to deal with wood are perfect. You still pay for the convience of bagged fuel and at some point isnt it just work it to burn liquid fuel. Even with my wood stove and "free" firewood i still burn oil in the early and late season.
/ Improving a Pellet Stove #39
Maybe it's a midwestern thing. Never heard of anyone doing it around here.
My sister tried pellets, gave up on it after a couple years for the reasons you mentioned.
Yeah, I don't light up the woodstove until we get consistently cold evenings (mid 20s or so), even then it's just in the evening. Don't run it full time until close to Thanksgiving. We do run the oil furnace sometimes first thing in the morning to take the chill off in early fall.
/ Improving a Pellet Stove #40
I have a very good friend who lived in Houlton, Maine (moved south because of the huge snowfall) that heated his home with a pellet stove as primary heat. A Harman btw. I understand that in Maine, you can have bulk pellets delivered to your door. I suspec there are a lot of pellet and bio fuel appliances out your way as well.
Swing over to Hearth.com Forums Home and take a look.
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
Caterpillar 416/426/428/436/438B Backhoe Service Manual (A63117)
Caterpillar...
KUBOTA LA535 FRONT LOADER ATTACHMENT (A64280)
KUBOTA LA535 FRONT...
2012 VOLVO SD105DX SMOOTH DRUM ROLLER (A64279)
2012 VOLVO SD105DX...
PULL PIN BOOM SPRAYER (A63291)
PULL PIN BOOM...
KMC 3pt 5' Rotary Tiller (A64119)
KMC 3pt 5' Rotary...
