Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #1,371
this is the thumb kit used on my L12. had to make a bracket to get it to work. used 1" thick plate. 1" carbide hole cutter. it is 2" wide.
Interesting product you linked.
Not all the 1-tonish Chinese machines come with the brackets for the mechanical thumb. For the ones that do come with those brackets, they are positioned poorly for a hydraulic thumb. That is why I cut mine off and started over.
Also, any hydraulic thumb (as in the photos) that does not have something welded between the 2 teeth near the tips will eventually get bent.
   / Importing and modifying a new mini excavator from China #1,373
Why don’t these just use a longer bucket pivot pin and go on like a thumb is supposed to? Then you would only have to weld one thing onto the stick and it will work better.
If you share the bucket pivot with the thumb pivot, the biggest problem will be breaking the 25mm pin. These machines use 2400psi hydraulics, plus a shared pin will need to be greaseable in 3 locations, if secured to the thumb.
You can certainly share the pin, but it really needs to be at least 30 mm diameter, and fully greaseable. That's my experience, from making hyd thumbs for numerous Prairie Dog backhoe attachments.
   / Importing and modifying a new mini excavator from China #1,375
the geometry is sub-optimal, but is works. did not want to take the plasma cutter to the new machine. will fine tune this winter. pulled a couple stumps & live trees this week.
   / Importing and modifying a new mini excavator from China #1,376
I do not like the geometry on my thumb as it interferes with digging when the boom is extended. It needs cut and modified. I've already bent the thumb pretty bad so looks like the torch has to come out anyways.
I wrapped my exhaust with ceramic under the shield then wrapped the outside with self stick foil. This made a difference on keeping heat out of the house. at Night the whole inside of the exhaust was glowing bright orange. At least it should be burning anything off like a cat does.
  • Good Post
Reactions: 1hp
   / Importing and modifying a new mini excavator from China #1,377
The thumb on the 4000Lb machines tuck pretty close to the boom, but the tines support were questionable so I welded 3/8" x 3" steel between the tines at the back and near the ends.
I have picked / moved 20"+ size rocks with no issue or bending.
  • Good Post
Reactions: 1hp
   / Importing and modifying a new mini excavator from China #1,378
welded doubler plate & eye on bucket.
   / Importing and modifying a new mini excavator from China #1,379
   / Importing and modifying a new mini excavator from China #1,380
replaced hour meter with multi-gauge & battery tender socket. also rewired ignition with one from my old JD160 lawn tractor. left battery cutout.
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
1979 HEIL TRANSPORT TRAILER (A58214)
1979 HEIL...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A57453)
2015 Freightliner...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
