imported rototillers etc
/ imported rototillers etc #21
<font color="blue">some of the small tillers I would be interested in are offset capable </font>
Most of the smaller tillers can be offset 5-6 inches right or left by siding the hitch over on the toolbar--This is usally enough to get you out past the rear tire for close edging work and does not put the Powershaft in any danger--Ken Sweet
Sweet Farm Equipment LLC *1 Hour South Of the National Farm Machinery Show*
Hi Bird,
OK, thats sounds pretty easy. So, theres nothing to mess w/ as far as power transmission is concerned? That is, only the 3pt hitch gear is the only thing that moves and nothing else. So, what was the max offset and was it only to one side or both?
Im planning to get a tiller wide enough to cover my wheels (around 48" or so). I was mainly thinking about using offset to till up against walls, pads, etc, places where it would be too close if the tiller wasnt offset. jimg
Ive never really looked at a slip clutch closely so bear this in mind in regard to my question: How exact must you be in the setup you described? I mean if the plates are cocked then you dont get the full benefit of the clutch b/c of the uneven bearing. Perhaps its not terribly sensitive to inexact setup.
As for clutch plates that bond together over time: my TC24 came w/ a small block thats used to keep the pedal down and the clutch plates apart when the tractor wont be used for an extended period. This keeps the plates from bonding together. This must be the same thing going on w/ the slip clutch. jimg
/ imported rototillers etc #24
Jimg, I think the offset can amount to 3" to 6" on different models. 3" was enough for me on mine. If you go to Bush Hog's web site, you can find "downloadable manuals" for many of their pieces of equipment. And I know the manual for the tillers describes the proper procedure for adjusting the slip clutch (and also tells you that it needs to be done periodically).
/ imported rototillers etc #25
Hello Dave,
<font color="red"> Instead of a tiller... have you considered a spader ? </font>
What is a spader? Picture maybe?
Thanks.
They're sort pf pricey!
/ imported rototillers etc #28
Ken,
Is that the First Choice tillers that have rust problems?
First Choice Tiller Rust Problems Thread
I noticed at the November 2003 EIMA Show the show units had the same scratch marks in the same area. Looks like they would fix this.
/ imported rototillers etc #30
That is what powder coat does when water gets under it. The only resolve for powder coat problems like this is to grind to bare metal, prime and paint. Powder coat is not everything that it is cracked up to be...(pun intended). There are two types of powder coat that I have learned about. One will crack and allow moisture to get under it, the other bonds to the metal so tight that it is next to impossible to damage it. That process costs a lot more to have done and it isn't practical for most things. There is a company that comes to the Carlisle Auto flea market in PA that brings along an anvil and hammers so you can try to chip the powder coat that they apply to metal. I have seen some badly dented metal, but never have I seen any powder coat remove. I did some reproduction car parts a few years ago and had them powder coated with this process. Since they are stone guards, I knew that they had to hold up and they have. Not one complaint... except for the price....
/ imported rototillers etc #31
It is definately true that a bad powder process is no better than a bad paint process and that there are a lot of formulations for both paints and powders. To further complicate things, there are a lot more variables to powder than liquid paint. But in the case above, any coating that is damaged would have done nearly the same thing. Once a scratch penetrates to the metal, corrosion begins to spread. That would be true for powder or liquid processes.
/ imported rototillers etc #34
Thanks Junkman, /forums/images/graemlins/laugh.gif
Ya learn something new everyday. /forums/images/graemlins/cool.gif
/ imported rototillers etc #36
</font><font color="blue" class="small">( I made a set of dollies for my tiller that slip over the depth runners. They are simple to make and they sure make it easy to install, remove and store the tiller (picture attached).)</font>
I wish you had posted this about two years ago when I got my First Choice tiller. I made a dolly out of scraps of mahogany. The mahogany was from the crate my first Kubota was shipped to the dealer in. The tiller is built like a tank, and until I saw your dolly, I thought the dolly was pretty nice too.
/ imported rototillers etc #37
Hello Will,
Maybe you can help Nomad with his equations. He can read the books but his applications are misapplied. As well he claims to have 30 years engineering experience and he is only 44 years old. I can not understand this math, is this the new math?
/ imported rototillers etc #38
WOW!!!! /forums/images/graemlins/shocked.gif
Mark, that's a new low, bashing someone who isn't even a part of this thread. I know he revealed your deep dark trade secret a couple a threads ago, (yes I saw it /forums/images/graemlins/grin.gif) but Will hasn't been a part of the threads where Nomad has been active.
I have seen the attacks on Nomad just recently, but as someone with a similar background, I have to say he has somewhat accurately with respect to his over simplification of the process displayed he has an understanding Computaional Fluid Dynamics. Nomad claims to be 40 years old, or at least that's what I remember. He claims to have been farming since 11 on and off. Twenty years of farming (perhaps gentleman or hobby farming): 11 + 20 < 40. He did not claim that his farming and years in the University were exclusive. Education, 16-18 years for primary/secondary school + 3-4 for an undergrad, plus 4-10years for two Ph.D's: worst case, 18 + 4 + 10 < 40. He claimed to teach for 10 years and 10 years of research. Again these are not exclusive, I know from first hand experience. In fact, it is quite reasonable, even expected to claim much of this experience as professional experience while working on a Ph.D. That is the way it is done in the U.S., my last two employers credited my years as a graduate student as professional experience($$). Now Ph.D study is not necessarily year-round study, Nomad, much like I was, may have been encouraged to spend some of his summers in industry to gain a better perspective in his field of interest. I spent one summer working at an Air Force Wind Tunnel facility, and another summer working in Germany for the German NASA (DLR). It is quite possible that he finished his education in his early-thirties, assuming and has been employed in industry until this point in time, thus giving him maybe 8 years of continous engineering experience, plus how many summers that he may have worked in industry during his education. If he wasn't employed as a professor, it is quite possible, his only publications were his dissertations and those may not have been submitted to journals.
Now that I have finished my defense, I must admit that I am using U.S. standards of education and can't positively say how it is done in Turkey.
Before anyone accuses me of not know what I am talking about since their experience may have been different than my own, here is a landmark paper that my professor (who teaches, does research, & runs a company simulataneously) and I wrote. If you do some internet searches, you will find that people from around the world have cited my work and my methodology has turned up in some interesting places, such as the movie The Mummy and several others. Physics of Fluids
Finally, a Ph.D doesn't mean that you are an authority on everything, it just means that you know one thing really well. Sometimes, we forget this little fact. /forums/images/graemlins/wink.gif
/ imported rototillers etc #39
Dave, even though frequently questioning my degrees/titles/etc, I'm trying not to go into details of my background as this forum is not a place to submit resumes to find a job. I am trying to talk only on technical things using a simplified language that everybody can understand. This way, talking only on technical matters, I guess, is more fun than talking about our titles, degrees, etc. If someones hadn't frequently asked what my background, what my degree titles, etc etc were, I wouldn't have said on this forum I had spent years on the researches. Ask NewAgtalk forum where I have frequented there and talked there for 4 years - folks there don't know what research background I have if I didn't mention once in last months. Having said these, maybe, I should tell a little now so that "some" can learn "new" old mathematics.
Age 11-14 to 40: On and off 15-20 years farming (sometimes like-full time working at the nights, sometimes part-time, etc). I didn't say exactly 2 decades. I said "about" 2 decades farming. By mentioning this, I meant I am not a new to farming at all.
Age 15-18: High school (industrial, engine/motor dept.) During this period, I also worked at small industry (repair of cars, tractors, etc) as a worker.
Age 18-23: Undergraduate education in mechanical engineering (took 5.5 years because 1 year was for learning languages and I didn't go to university for 1 year due to my economical reasons.) During this period, I also worked at the small industry as a technican and part time (summer, etc) farming.
Age 23-25: After the graduation, full time engineer at a petrolium valve industry and at the same time I started my master degree MSc in engineering.
Age 25-27: Moving from the industry to my university job at 25 (as teaching&research assistant) and completed my MSc there at university and also travelled to international research centers also during this period to learn and gain experiences on modern experimental studies in fluid dynamics.
Age 27 - 35: Started my PhD at mech. engineering at 27. At the 4th year of PhD study in fluid dynamics, I was actually independent of mechanical engineering staffs as I had gone into more theoretical (mathematical) approaches and mech. engineering staffs were not helpful on my engineering PhD anymore. At 4th year of my engineering PhD, I was actually playing with formulae like a mathematican. This is the year I moved my PhD and research & teaching job at the university to mathematical physics department of science faculty. I was like 30-31 yrs old. My new PhD thesis there was a group theory (a mathematical branch - infinitesimal point symmetry groups) and its applications to classical physics. Since I was familiar with fluid flows in my previous studies in engineering I had applied this kind of semi-pure mathematics to fluid flows in general and chaotic/turbulent flows in particular. I was using symbolic algebra/mathematics (Matematica Software based on C++ was newly popular at that time) to analyse the nonlinear partial differental equations and to lower their dimensions using newly found symmetries. Then, Since I was pursing PhD I had MSc students preparing simple computational fluid dynamic programmes written in Fortran for my specific test flow cases. I handled not only one specific flow type, but many different flow types as I was searching symmetries in a generalized version of turbulence (i.e. full space-time Navier-Stokes equation). Sometime an inviscid flow, sometimes dissipation dominated flow, sometimes simple one dimensional nonlinear wave flow. I also played with equations of other fields such as biomechanics, economics, electromagnetics, etc. Since mathematicans weren't understanding from engineering (emphirical) equations of fluid dynamics I was educating the pure mathematic professors there about them and since engineering professors weren't understanding from pure-mathematics I was educating them about their engineering formulaes in engineering field. This is why I am saying I had students who were old age professors. One of my studies was to combine pure math. and engineering application; a study of infinitesimal symmetries of a full engineering emphirical equation formed by engineers after lab. tests.. This study was very important because computational engineers were solving their emphirical formulaes using computational fluid dynamic programmes. My so-called PhD supervisor had forced me to publish this study or to give a seminar at a national classical mechanic meeting. I did join, but while I was presenting my specific study, I had to fight some scholars whose sole intention was to attack personals as they usually do before approving your PhD title. You know you need to kiss a** all over the world when you want to get your degree especially if it is a PhD that will title you and put you in the system of zen-ish scholars powering the system with irrelevant, semi-politics business scholing games. That's why I always hated to publish the studies. But, hey, many professors have published parts of my studies without using my name and without giving any reference. Thieves aren't only in businesses, but also in the science much, much.. By the way, since internet (Gopher,ect) was introduced more after 1990s, I was like an independent researcher exchanging studies with young PhD scholars around the world around different universities and research centers like Nasa because my studies (at science faculty) were symbolic mathematics and internet was sufficient enough to exchange the simple symple symbolic algebra programmes via email, internet.
Okay - it became a long story. As seen here, 8 years PhD research studies during 27-35 (if we also add 1 year of MSc, it's 9 years.) and 9-10 years of teaching & research job at the universities between the ages 25/26 and 35. Left the university at 35 mainly due to economic reasons. Engineering, consultant, etc again a year or two after 35 and foreign trade, etc in last years as well as hobby farming, etc.
Well, this became like a resume - and I am not good at writing resumes. Should I also say my hobbies? lol - okay, here is; I am like a professional player of these games; billard, bridge (card game), table tennis, etc (but not made any money from these games - so, I am not a professional, but very good at these games.) - well, I can also make knots at a weaving loom to make rugs that I call "natural fine arts" - Whatelse should be told in a resume? lol
Okay, I don't want to go into irrelevant talks more. Last one question to Dave; I read the abstract of your study on that page you gave. One thing I didn't understand there is that you add a new term? Is this "new term" an artifical numerical term which doesn't exist in the partial (semi-emphirical?) differential equations there? and was that new term behaving exactly like a dissipation term in the flow equations? I mean this new term added to numerical/discreatized equations wasn't disturbing actual physical original form of flow. I have a feeling that you did somethings like a conversion of physical Eularian flow to a kind of flow with some little dissipation, a flow with a dummy small visous term. Was this no problem because your equations had some semi-emphirical parameters? Unless you disturbed the flow numerically, it's a good study. Otherwise, it can trick nonlinear potentials there. Anyway, I can't say I am good at the computational fluid dynamic or at tricks of discrete formulizations.
Ps: As seen here, I can talk about anything. lol - So, whats your problem CCI? We can also talk about them here in this thread. What? Painting of Pieter's tillers aren't so good? Pieter is also a painter artist- he can paint an even a pictoral scenes on his tillers lol.
Ps2: edited to say: I'm 40 and I agree with Dave in that having a research title doesn't mean you are an authorized one although most of professor scholars consider themselves so. To me, whoever making money is authorized - but also RESPONSIBLE!
/ imported rototillers etc #40
Tell us Nomad the difference between Knowledge and Wisdom.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
