Implement to ground
/ Implement to ground #1
Jose
Hi there,
Is it necessary to egaged the PTO to allow up or lower the implement to ground?
p.s. My tractor is an Yanmar 3110D
Rgds
Jose
Mozambique
/ Implement to ground #2
If your Yanmar doesn't have 'live' PTO, then it will be necessary to have the PTO 'engaged' to raise the 3point arms. However, it shouldn't be necessary to lower the 3point arms.
The reason for this is the pump is on the PTO drive shaft in the transmission.
However, if you have live PTO (pump is driven full-time), running the PTO should not be necessary to raise the 3point arms.
Tnx
Any special precaution is needed before engaged the PTO? It seems it will be need to be engaged...
Rgds
Jose
Mozambique
/ Implement to ground #4
"If your Yanmar doesn't have 'live' PTO, then it will be necessary to have the PTO 'engaged' to raise the 3point arms."
Is that just a quirk of the YM3110? My YM2000B does not have live PTO and there is no connection between the PTO and the 3PH other than sharing fluid. The 3PH is fully operable without the PTO engaged.
/ Implement to ground #5
I would only think one precaution, and that would have to do with whatever you might have connected to the PTO.
Regards,
/ Implement to ground #6
This is a mis-definition of "live pto". A live pto is one which can be engaged and disengaged, and runs independently from the transmission. That is, when you depress the clutch to disengage the transmission, the pto will continue to be powered. The confusion comes when we start talking about the 3 pt hydraulics - which is NOT the pto. As far as I know, all Yanmars have the hydraulic pump driven directly by the engine, not from the transmission.
Older U.S. tractors like the Ford 8N have the hydraulic pump driven by the transmission - so you have to have the transmission turning to use the 3 pt hydraulics. The clutch pedal must be out to turn the hydraulic pump and raise an implement. This is not true for the Yanmar tractors.
On the other hand, most Yanmar tractors do NOT have a live pto. The clutch must be out to power the pto, and it is not independent of the transmission. So when you need to put the tractor in gear to drive, you depress the clutch pedal and the pto stops.
I hope this helps to better define hydraulic and pto functions.
Nice words gbirky....
Tnx for explanation. As metter of fact since my tractor have the front loader from factory, there´s a gear near the FEL gears, which must be engaged to up or lower the implements as well to use the FEL.
Rgds
Jose
/ Implement to ground #8
Jose,
What kind of gears are they and how are they related to your FEL? Aren't they operated hydraulicaly or are they somehow mechanical? Maybe you mean valves? Sorry for so many questions but I am following along and trying to understand the problem.
Mark
/ Implement to ground #9
Jose,
I have a really nice YM3110D and hydraulics are live on that tractor. The hydraulic pump is gear driven from the front of the engine not the PTO or transmission. The pickup screen is in the bottom of the rear of the transmission housing facing out on the back of the tractor, just below the PTO shaft. 3 bolts hold the cover on. I always check that, often it is plugged with gunk. From the lower right side (if seated on teh tractor) follow the two metal lines (tubes) up the transmission side towards the front of the tractor. One should be twice as big in diameter as the other. The big one is the suction line, the smaller is the pressure line. I would bet both lead to the front of the engine as mine do.
Feel free to email if I didn't make sense, coffee hasn't kicked in yet.
Nick
Hi Mark,
As matter of fact it’s a valve (looks like a gear). The same type (with small difference), use to control the FEL (plse see photos in attach). This valve blocks the hydraulics from the pump which comes from the motor side. So it must be open if you want to work with the 3 point arms.
Hi Nick,
Do you have FEL installed on it?
Rgds
Jose
When you push down. If you move back it closes. BTW to work the PTO is it necessary to use the gear or the clutch must engage?
Rgsds
Jose
Mozambique
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
Cub Cadet Pro Z 972 (A64127)
Cub Cadet Pro Z...
1901 T/A CAR HAULER TRAILER (A59914)
1901 T/A CAR...
