Implement Stand Ideas ??
/ Implement Stand Ideas ?? #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
My Kodiak 6' Landscape Rake needs something other than blocks of wood to hold it in position. What have you folks designed/fabricated ?? Any suggestions will be appreciated. Thanks, Eric
/ Implement Stand Ideas ?? #2
Looks familiar. I had the same problem on my landpride rake. Let me get a picture of what i made.
/ Implement Stand Ideas ?? #3
A short piece of 1-1/4" pipe welded to the frame with a pin hole drilled in it. Then a 1" pipe with two holes drilled in it for the leg also with a flat plate for the foot. One hole for holding the implement up and the other for storage when the implement is in use.
/ Implement Stand Ideas ?? #4
1st picture
/ Implement Stand Ideas ?? #5
sorry dial up and im having problems i'll get you a picture some time
Barnboy....
Thanks for pic. This is similar to what JerryG explained. I like that design/setup. I appreciate you sharing that with me.
/ Implement Stand Ideas ?? #7
Not being prepared to do any welding I went to Harbor freight and bought a cheap <$20 trailer jack and clamped it on the beam on my Land Pride Landscape rake. The trailer jack is one that rotates to horizontal so that it is out of the way when using the rake. I bought 2 so I have one to put on the rear blade also.
Vernon
/ Implement Stand Ideas ?? #8
Here's the stands I built for my #71 Deere planter
/ Implement Stand Ideas ?? #9
'Nuther view of the same.....
/ Implement Stand Ideas ?? #10
Indy,
those look so much better than what we used to use. Old 5 gal steel pesticide cans and the often handy blocks & pieces of railroad ties, or fence posts or what have you. You know, how do you get your plow to stand upright? Drop it down and pull it til it's stuck good!
That was oolldd school!
/ Implement Stand Ideas ?? #11
The plow I keep at the house sits upright on its own. The 5-bottom and 6-bottom plows at the farm have a "kickstand" that came on the from the factory.
The "legs" on the planter were added because I just got sick of looking at a stack of 5-gallon buckets under such a nice planter.
/ Implement Stand Ideas ?? #12
<font color="blue"> bought a cheap <$20 trailer jack and clamped it on the beam on my Land Pride Landscape rake. </font>
I did the same thing with my Landpride rake. With gage wheel on it rolls around the barn without problems.
/ Implement Stand Ideas ?? #13
Is it just me, or does it make sense for the manufacturer to just add these types of “conveniences” as standard equipment? I mean, how much $ could these simple yet effective “kickstands” add to the manufacturing costs of these implements?
/ Implement Stand Ideas ?? #14
</font><font color="blue" class="small">( Is it just me, or does it make sense for the manufacturer to just add these types of “conveniences” as standard equipment? )</font>
Some manufacturers do have kick-stands as standard equipment. My Woods 7' rear blade has one on it. Also my CCM tiller has a factory stand. I agree with you though I think it should be standard accross the board.
/ Implement Stand Ideas ?? #15
</font><font color="blue" class="small">( Is it just me, or does it make sense for the manufacturer to just add these types of “conveniences” as standard equipment? I mean, how much $ could these simple yet effective “kickstands” add to the manufacturing costs of these implements? )</font>
DMF,
A lot of equipment does come with legs now. But, you know, it would only cost the manufacturer $20 or so to add them when they build the implements. (unless it was JD, better make that $50) It would seem to me that just to save possible future litigation, that everything would come with a set of stands. From the initial assembly at the factory to final assembly at the dealer, you would think that they would not want an out-of-balance several-hundred pound object to fall on someone.
What's puzzling is that most post hole diggers are still without any type of supports.
/ Implement Stand Ideas ?? #16
As Gene said, Woods does this with their stuff. I had one on my rear blade, landscape rake and tiller all of which were Woods.
/ Implement Stand Ideas ?? #17
Indydirtfarmer-
Could you give us an idea of the stock and hardware used to make your stands? What should I have on my shopping list when assembling the parts to make a couple cool stands for my stuff.
-Dan
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 International...
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A67147)
2016 INTERNATIONAL...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
