implement arm won't lower
   / implement arm won't lower #1
iammike
B7100 hst implement arm raises but doesnt lower. I suspect the control valve.has any one else run into this?
   / implement arm won't lower #2
Have you checked your Rate of Drop (ROD) knob to make sure it's not all the way closed? This knob controls the speed that the arms lower at and can stop them from lowering if completely closed.
Yes, I even backed it off counter clock wise to be sure. It was working and then Quit as I was finishing up my drive. It was also making noise when I lifted the blade.
   / implement arm won't lower #4
I saw that you also posted in the Hydraulics forum. That's probably a better area for this, so I'll watch how this comes out in that thread.
   / implement arm won't lower #5
Normally found under the seat, in the middle...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
Kubota BX2230D (A47384)
Kubota BX2230D...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
3 plastic drums (A53117)
3 plastic drums...
2014 DRAGON PRODUCTS STEPDECK 46 DOVETAIL W/RAMPS (A53843)
2014 DRAGON...
