Impact Gun on transmission drain plug?
   / Impact Gun on transmission drain plug? #11
Pipe wrench.
   / Impact Gun on transmission drain plug? #12
   / Impact Gun on transmission drain plug? #13
My opinion is that the impact gun is riskier to the threads if they are seized, but less likely to wrinkle (damage) the pan.
   / Impact Gun on transmission drain plug? #14
This would be an ideal application for an old-school manual (hand hammer driven) impact driver. Most I have ever seen have a 3/8" square "output". Does that happen to be size of your plug?
   / Impact Gun on transmission drain plug? #15
File or grind it square again on 2 sides and make it fit a open end wrench. Then a pipe wrench if no go. Then if not out, drill it out and use a tapered easy out.
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
John Deere 950 Tractor (A57453)
John Deere 950...
SKID STEER ATTACHMENT SHREDDER (A58216)
SKID STEER...
2010 FORD F550 XL SUPER DUTY SERVICE TRUCK (A58375)
2010 FORD F550 XL...
116 Gallon Poly Fuel Tank W/12V Pump (New/Unused) (A59225)
116 Gallon Poly...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59575)
2018 INTERNATIONAL...
