Impact Gun on transmission drain plug?
   / Impact Gun on transmission drain plug? #11
Pipe wrench.
   / Impact Gun on transmission drain plug? #12
   / Impact Gun on transmission drain plug? #13
My opinion is that the impact gun is riskier to the threads if they are seized, but less likely to wrinkle (damage) the pan.
   / Impact Gun on transmission drain plug? #14
This would be an ideal application for an old-school manual (hand hammer driven) impact driver. Most I have ever seen have a 3/8" square "output". Does that happen to be size of your plug?
   / Impact Gun on transmission drain plug? #15
File or grind it square again on 2 sides and make it fit a open end wrench. Then a pipe wrench if no go. Then if not out, drill it out and use a tapered easy out.
yellow ball Trailer (A56859)
yellow ball...
1998 Caterpillar 12H Articulated Motor Grader (A55973)
1998 Caterpillar...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
