Impact Gun on transmission drain plug?
   / Impact Gun on transmission drain plug? #1
CTMassey
Massey-Ferguson 1529
Silly question, went to drain my Transmission oil on my Massey 1529, and the drain plug started to round off. I immediately abandoned the mission before it got real bad and ordered an Irwin bolt grip socket to try and remove it. So, is an impact gun a good or bad idea to use ? I haven't tried the breaker bar or ratchet yet but was just wondering what peoples thoughts were...... Thankyou for any input!!
   / Impact Gun on transmission drain plug? #2
An impact might just do the trick better than brute force with a breaker bar. Have to make sure your socket fits well.
   / Impact Gun on transmission drain plug? #3
Make sure you use a 6 point socket, 12 points just catch the corners.
   / Impact Gun on transmission drain plug? #4
Is it a square plug. There are special scokets for square heads.
I would and have used an impact wrench to remove a lot of things that you are not suppose to. Including spark plugs.
Start out low on the impact.
   / Impact Gun on transmission drain plug? #5
The vibration from and impact will often shake loose a stubborn fastener. I would go at it easy though.
   / Impact Gun on transmission drain plug? #6
Bad idea. You have no 'feel' for the fastener's willingness to loosen when using an impact gun. If you strip it you're done.
I'd go with as small a breaker bar as possible and work up. If it won't start to move you may be up ****es creek Try tapping on the flat part of the bolt head first to vibrate the threads loose, if at all possible. Sometime that can work...
   / Impact Gun on transmission drain plug? #7
Impact would be tempting if you start real easy. I would prefer a breaker bar so you could feel the tension. Also, add some penetrating oil as best you can. That's where it's sticking.
   / Impact Gun on transmission drain plug? #8
I wouldnt have a moments hesitation using an impact.
Penetrating oil is going to be of little help IMO. Because its a drain plug, not just a bolt. It will likely have a copper washer or rubber washer (or even pipe thread) that is designed to SEAL. And its a drain plug, threaaded up into an oil pan. So there is plenty of lube. Seized is not your problem. And overtorqued plug is your problem
   / Impact Gun on transmission drain plug? #10
I would expect a proper fitting square plug socket to be the solution. Just put that on a breaker bar and have at it. Sounds like you were using a crescent wrench, which should really be called a "bolt head stripper".
49205 (A55788)
49205 (A55788)
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
9000 (A47477)
9000 (A47477)
2017 Ford F-450 Service Truck w/ Liftgate (A56858)
2017 Ford F-450...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
