IMO, the worst thing about Power Tracs...
   / IMO, the worst thing about Power Tracs... #11
<font color="blue"> the worst thing about Power Tracs </font>
<font color="red"> is that once you own one, you can't seem to do any job without it!!!! In 1-1/2 years I have used my PT-425 for 225 hours without doing any snow or grass!!!</font>
/forums/images/graemlins/shocked.gif
   / IMO, the worst thing about Power Tracs... #12
The big stuff I take to the local shop
<font color="blue"> ========== ============ </font>
When you say shop what kind of shop are you talking about?
Auto dealer
Mechanic
Garage
Tractor Dealer
Welding
Machine
I have no Idea who would work on A power trac around here.
What type of shops should I be checking out?
   / IMO, the worst thing about Power Tracs... #13
</font><font color="blue" class="small">( Guys, I spent at least a year and a half reading this forum and looking at Power-trac's site every day before I bought mine. It would have been longer if Mac hadn't sold me his 422. )</font>
Why what took you so long?
What's holding me up is No local dealer support.
It's strongly emphasized all over TBN the importance of good dealer support when buying any tractor.
I don't see where dealer support is any less important simply because the tractor happens to be a Power Trac.
   / IMO, the worst thing about Power Tracs... #14
Can anyone post a picture of your PowerTrac? Maybe one of both models I have heard discussed. I am from SC and I was orginally from Virginia. Independence, Va. was where I moved from to SC. Thanks
Jim
</font><font color="blue" class="small">( The big stuff I take to the local shop
Auto dealer
Mechanic
Garage
Tractor Dealer
Welding
Machine
)</font>
Then perhaps you should carefully read some of these replies -- Bob's already answered these points quite clearly...
1. Small engine shop for the motor
2. Either a hydraulics shop or tractor dealer for the hydraulics
That's basically all there is to a Power Trac. There is no transmission, clutch, transfer case, axles, mechanical PTO, mechanical steering, water pump, radiator, fan belt, etc. like you have on a "normal tractor"...
It's hydraulic pumps, hydraulic motors, hydraulic cylinders, and hydraulic controls -- with the pumps directly coupled to the engine....
Part of its "beauty" is that simplicity...
</font><font color="blue" class="small">( Can anyone post a picture of your PowerTrac? Maybe one of both models I have heard discussed. I am from SC and I was orginally from Virginia. Independence, Va. was where I moved from to SC. Thanks
Jim
)</font>
Jim, here's a post with pictures of my PT425:
My Used PT 425
   / IMO, the worst thing about Power Tracs... #17
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Can anyone post a picture of your PowerTrac? Maybe one of both models I have heard discussed. I am from SC and I was orginally from Virginia. Independence, Va. was where I moved from to SC. Thanks
Jim
)</font>
My Used PT 425 )</font>
Thank you. An interesting piece of equipment. Sorta reminds me of a Cat loader and a bobcat mixed together in one. Looks like it would have a fairly decent size engine as well. What HP? Am I correct in assuming there is special equipment for that nice piece of machinery?
Jim
   / IMO, the worst thing about Power Tracs... #19
</font><font color="blue" class="small">( Jim,
This one's a 25HP gas. They also have 18 and 22 HP gas, then 30, 45, and 60 HP diesels. Here's the assortment of attachments available to fit mine:
T8 Class Attachments
Power Trac Home Page )</font>
WOW! I could spend a small fortune for attachments like that. I would want one of each. A very nice system. Really reminds me of a Bobcat because most all the attachments operate from the front. Thanks for the links, I will check them out.
Jim
They have a lot in common with a skidsteer, but, being articulated, they operate more like a "payloader" or "wheel loader"...
They don't spin and tear up the lawn like a skidsteer will, and are almost as maneuverable.
The attachments, while using a proprietary Quick Attach system, are also less expensive than Bobcat attachments...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2004 Delta Spread-Axle Gooseneck Trailer. 20ft+5ft. (A56438)
2004 Delta...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
159119 (A60430)
159119 (A60430)
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
