Imatch Compatability List
/ Imatch Compatability List #1
BloomingtonMike
Platinum Member
John Deere 3320
We should start a list of items we know work with Imatch and or the mods to make them work. Also if the items work with the Speedco we should list that too (if it does not work with Imatch but does with Speedco). Any other items list as well - and yes we know Pat's works with everything.
Frontier RB2072 works out of box. Added busings.
King Kutter Cary All was modified - Added two Arms slightly above the originals to hold the Cat1 Pins. Added bushings to the pins.
Info request:
Does the 60" King Kutter II Tiller work with Imatch.
/ Imatch Compatability List #2
Great idea! I have been able to use just about everything with my Speeco quick hitch. To make changeovers more effiecint, I have modified the top hook to use 2 grade 8 bolts and instead of tightening nuts on them, I drilled holes in them and use hitch pins. To change the poistion of the hook takes less than 20 seconds. Each implement has its own hole setting. All of the John Deere I match stuff uses the hook in its lowest setting. Seems as if all older Land Pride uses the 2nd from the top. I use the bushings on all the implements.
/ Imatch Compatability List #3
Good Idea, here's my list--
LX-4 and LX-5 worked right off
Woods GB48 box blade--works, with about 1/8" to spare--kind of a pain
JD 60" Landscape rake worked out of box
agree on 72" blade
All above with "normal bushings"
Ballast Box needed the "extended" style bushings to work correctly, otherwise the lower hooks were always bending one of the linch pins /forums/images/graemlins/tongue.gif
/ Imatch Compatability List #4
Anyone use any spreaders - the conical 3 point variety - with the IMatch?
/ Imatch Compatability List #5
I have the JD ballast box, just purchased this fall, and it works with the I-match with no modifications. I also have the Frontier 7 foot blade and an MX-6 mower, they all hook right up to the I-match (you do have to put bushings on the pins). I bought a Frontier 1060E finish mower today and it does require a conversion kit. I went with the Frontier so I would be assured it would be compatable with the I-match.
/ Imatch Compatability List #6
Someone needs to make an alphabetical list and the add it to the Deere FAQ.
Mike, where have ya been? You have not posted in awhile. I was going to emial you to see if everything was OK.
/ Imatch Compatability List #7
TTT
The Frontier spreaders are NOT IMatch compatible.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
Kubota L2501 (A62177)
BRUSH GUARD & RACK FOR UTV (A64276)
BRUSH GUARD & RACK...
CHAIN LINK FENCE (A64281)
CHAIN LINK FENCE...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
