IH Hydro 100
/ IH Hydro 100 #1
DLTTrekkers
Paarl South Africa
This tractor does not want to move . No forward or reverse.
I did check and replace the hydraulic filter. It was cloged up with some cloth. Someone before me left his cleaning cloth inside.
I also removed the charge and mainpump and had it checked out. This is the pump on the right side of the gearbox.
Then I removed the other pump just infront of the left rearaxle. There I found the rest of that cloth.
Then on some advice I removed the pto pack and stripped it. Its pick-up was block aswell and the plates was burned out. I overhauled it and that is working now. I do get oilpressures at the hidge and externales and at the pto.
No oilflow at the inching pedalvalve.
Help is needed please ?
/ IH Hydro 100 #2
Damn that is a shame that someone did that.
I always liked the Hydro 100 especially after a turbo gets added to them for more pto power.
An awfull lot of small ports that can get plugged up with fibers.
Good Luck getting her going.
/ IH Hydro 100
Still working on this tractor.
At this port I do get 400 psi and I can adjust it more.
At the bottom testport I do not get any prssure
/ IH Hydro 100 #4
Wow... just wow....
I don't know the answers to your questions. I've got a 1066 and go to an IH site for some learning (or asking) on working on it.
Those fellas over there eat, breath red and probably won't marry it unless it's red. There is a lot of IH technical experience there. (not to diminish this site)
/ IH Hydro 100
With no help I found these checkvalves fitted the wrong way. I am about to start this tractor and test it.
/ IH Hydro 100 #7
Dang thought you had it at first.
/ IH Hydro 100
I looked at the pistures and found this pin shorter than it should be .
Will make one that will be longer and then test it
/ IH Hydro 100 #12
Congratulations, good to hear.
They were a nice tractor for general work and great on pto jobs.
I ran one a lot doing cultivation and irrigation couragations for flood irrigation.
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
John Deere 50 (A60462)
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
