IH Hyd. with draft control
/ IH Hyd. with draft control #1
martin cox
Can anyone HELP ME. My IH backhoe hyd.started slowing down and then just about quit completely. I took the pump apart and it had some broken plastic(?) pieces in . I got a new pump.put it on with all new fluid. IT woprks real hard to lift the hoe or front bucket like the old one before it quit. I don't want to ruin the new pump. I found out the hyd. works through the draft control which I know nothing about. I'm not sure that is where the problem is or is it in the valve body control. Is there an adjustment in either of these. The only info I have available at this time is on micro fish machine and its not very clear. Thanks for any help MartinC
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
PALLET OF 1 5/8 HYDRAULIC HOSES (A65643)
PALLET OF 1 5/8...
2022 Case 5550 Trident Spreader LOW HOUR (A63689)
2022 Case 5550...
42in. Pallet Forks (A65640)
42in. Pallet Forks...
1999 Ford F800 Dump Truck, VIN # 3FEXF8019XMA05457 (A65563)
1999 Ford F800...
Gradall no crank no start (A61568)
Gradall no crank...
