IH B414 carb
/ IH B414 carb #1
canucklehead
frozen Canada
1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
I have a 1962 IH B414. I took apart carb to clean it and in the float bowl I believe there is an accelerator pump. It was stuck up, which would not allow the butterfly valve to open. I managed to push it down so now the butterly valve opens, but I think that part is supposed to slide up and down freely. Is this critical to operation of carb? Can I leave it in the down position?
where can I get a replacement part for it?
/ IH B414 carb #2
I had the same thing happen to mine. the accelerator pump locked up , even the linkage wouldn't operate because of that.
soaked the carb in gunk for 2 or 3 days. polished it up and it travels up and down freely.
Den
/ IH B414 carb
den, my float bowl is currently soaking in diesel fuel (recommended by my cousin). I was also wondering if solvent might work better. I'd also like to be able to remove the "emulsion block" from the float bowl, but one of the screws is seized.
/ IH B414 carb #4
sorry but I don't know about the emulsion block, as for the seized screw, more soak time there too might help.
if it breaks off no matter what, then the drill and broken stud/screw extractor comes to mind.
don't try to unscrew the screw all In one pass even then, working it back and forth repeadedly is the best bet, after soaking it a long time with something like pb blaster (similar to wd 40 but better in my opinion)
for the accelerator pump part, ya, I would use a solvent for that purpose to submerse it in entirely. a few days worth.
/ IH B414 carb
I soaked the pump chamber with PB Blaster overnight, but it didn't free it up. now it is immersed in diesel, but I think I'll swap that for solvent.
i haven't had very good success with easy-outs. mostly I've snapped them on these smaller screws/bolts. maybe I might take it to a machinist and pay as it'd be better than breaking off an easy out. they have special tools/drill bits, expertise, etc...
/ IH B414 carb #6
if it snaps you might have very good luck with a left hand twist drill bit. I use them a lot on broken screw extraction. use incremental sizes. usually the bit will grab and screw out the stud eventually.
/ IH B414 carb #7
Yeah, they work great. Just need to get it centered.
/ IH B414 carb
I don't want to double post everything. I have a very good write up and set of pics for this carb and my experience. Bonus that I was able to salvage everything. here is a link to my thread:
how does older carb work? mine won't stay running. - Page 3
oops, this link is page 3, but once you get there, go to page 1 and read, view pics, etc.. IF you need to do a similar fix.
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
2022 EZ-GO ELITE...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
