IH B414 carb
/ IH B414 carb #1
canucklehead
Gold Member
frozen Canada
1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
I have a 1962 IH B414. I took apart carb to clean it and in the float bowl I believe there is an accelerator pump. It was stuck up, which would not allow the butterfly valve to open. I managed to push it down so now the butterly valve opens, but I think that part is supposed to slide up and down freely. Is this critical to operation of carb? Can I leave it in the down position?
where can I get a replacement part for it?
/ IH B414 carb #2
I had the same thing happen to mine. the accelerator pump locked up , even the linkage wouldn't operate because of that.
soaked the carb in gunk for 2 or 3 days. polished it up and it travels up and down freely.
Den
/ IH B414 carb
den, my float bowl is currently soaking in diesel fuel (recommended by my cousin). I was also wondering if solvent might work better. I'd also like to be able to remove the "emulsion block" from the float bowl, but one of the screws is seized.
/ IH B414 carb #4
sorry but I don't know about the emulsion block, as for the seized screw, more soak time there too might help.
if it breaks off no matter what, then the drill and broken stud/screw extractor comes to mind.
don't try to unscrew the screw all In one pass even then, working it back and forth repeadedly is the best bet, after soaking it a long time with something like pb blaster (similar to wd 40 but better in my opinion)
for the accelerator pump part, ya, I would use a solvent for that purpose to submerse it in entirely. a few days worth.
/ IH B414 carb
I soaked the pump chamber with PB Blaster overnight, but it didn't free it up. now it is immersed in diesel, but I think I'll swap that for solvent.
i haven't had very good success with easy-outs. mostly I've snapped them on these smaller screws/bolts. maybe I might take it to a machinist and pay as it'd be better than breaking off an easy out. they have special tools/drill bits, expertise, etc...
/ IH B414 carb #6
if it snaps you might have very good luck with a left hand twist drill bit. I use them a lot on broken screw extraction. use incremental sizes. usually the bit will grab and screw out the stud eventually.
/ IH B414 carb #7
Yeah, they work great. Just need to get it centered.
/ IH B414 carb
I don't want to double post everything. I have a very good write up and set of pics for this carb and my experience. Bonus that I was able to salvage everything. here is a link to my thread:
how does older carb work? mine won't stay running. - Page 3
oops, this link is page 3, but once you get there, go to page 1 and read, view pics, etc.. IF you need to do a similar fix.
2015 JLG G12-55A TELEHANDLER (A65643)
2015 JLG G12-55A...
2011 CAT 430E BACKHOE LOADER (A65643)
2011 CAT 430E...
90in. Work Bench (A65640)
90in. Work Bench...
2018 KENWORTH T680 (INOPERABLE) (A65643)
2018 KENWORTH T680...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2019 CENTEX TRAILER 16' COOL DOWN TRAILER (A65643)
2019 CENTEX...
