IH 706 hydraulics problems
/ IH 706 hydraulics problems #1
doo
ih 706
Morning , I have a IH 706 with a loader with several problems , most important to me is while using it the hydraulic lift lever pulled out of the tractor in my hand with no visible cracks or breaks where it goes into the tractor thus rendering my tractor immovable as i have no way to make the loader move up or down ,what was that lever connected to and how do I fix it? My other problem is I have a difficult time getting the tractor into gear especially reverse without grinding a pound which I'm concerned is causing damage . The previous owner claimed they had the tractor split and trans. rebuilt professionally but I'm having doubts about that ! Any help would be greatly appreciated!
Any ideas????
/ IH 706 hydraulics problems #3
Grinding gears would indicate that you need to adjust the clutch. With engine off push on the clutch pedal with your hand. You should feel a change of resistance. I don稚 exact specs for your tractor but typically around 1 inch of movement before resistance change. Should be a turnbuckle assembly in the linkage for adjusting this free play.
Been to many years since was on an IH 06 series so don稚 remember how the hydraulic controls were routed. My suggestion is to look at the lever and the area it came out of. Should be some linkage or pivot points that it connects to.
/ IH 706 hydraulics problems #4
I looked at a parts diagram for your tractor. Keep in mind I do not know your model.
If one of the two levers I have identified in the parts photo is the one that came disconnected, it looks like they just slide into a sleeve and are secured with a pin.
Dave M7040
Thanks for the input , will give it a try!!!!!!
/ IH 706 hydraulics problems #6
What brand hyd valve controls frt end loader?? I agree with other poster that trans gears grinding indicates clutch disk not releasing or rough pilot brg shouldn't be caused by trans rebuilding
Will check brand this weekend!
/ IH 706 hydraulics problems #8
Does your 706 have a TA?
if so pull it then try your shifts.
Also if it has the TA the clutch adjustments have to be done correctly or it will not work properly.
Does have a TA , will try that ! Thanks
/ IH 706 hydraulics problems #10
That also has a internal clutching brake tied into the clutch/TA. Look on the left side.
You will see the usual clutch linkage/shaft and also another adjustable linkage.
A manual will give you the adjustment specs.
Till then you can help the shifting by engaging the brakes while shifting.
It will keep the innards from free spinning between gears.
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
