iH 574 Gas Starting Issues
   / iH 574 Gas Starting Issues #1
Barlow96
Pa
IH 574 gas
Well decided to start my 1974 IH 574 gas this morning (been sitting idle for 2 months) and no dice. Battery is fully charged and the starter is fine ( jumped the starter and it fired right up). When I shut it off and then try to restart I get nothing. I am thinking either a bad ignition switch or bad clutch relay switch. Any other thoughts or suggestions? Also how could I test the ignition switch to determine if that's the culprit.
   / iH 574 Gas Starting Issues #2
Get out the VOM and test that switch and relay.
Thanks. I wasn't sure if there was any other components inline. Turned put to be a shot clutch relay. Now does anyone know what the voltage output for the alternator should be? I am getting 12.07 at the alternator.
I think it's bad and need to replace. I did a search and am finding many options. Any ideas of a good replacement?
   / iH 574 Gas Starting Issues #4
I have the industrial version of the 574 mine is the 2500 and i bought a universal alternator works great.Its the same Tractor just built heavier.
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
Hydraulic rail grinder (A56435)
Hydraulic rail...
202475 (A54757)
202475 (A54757)
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
